Question about Dell Inspiron Mini 10 Notebook
MY DELL NOTEBOOK WONT TURN ON
My laptop wont turn on and also when i have the charger in it flashes white and red
    Problem Solver:
  • 6 Answers
Try a different power cord. You should have at least one spare. Spare power cords are available on eBay for $10 or so.
Posted on Feb 17, 2012
mewms_14904
  • 1027 Answers
SOURCE: wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
Posted on Apr 05, 2008
MerlinTech
  • 197 Answers
SOURCE: dell inspiron 6400 notebook wont turn on
try this with battery removed first..
plug in ac power, no battery,
then when turning on machine, press F8 to go to safe mode(pick the top option)
see how that works forya
Posted on Jun 14, 2008
naslicer
  • 73 Answers
SOURCE: red light flashing on far right symbol/battery or charger going ?
this happiness when you've used the laptop off power for some time. it indicts your battery levels. when the battery level is low to a certain %ge then it warns you before its totally empty. always power up your laptop whenever it lights or save your work in order not to lose unsaved data.
Posted on May 26, 2009
ktes870
  • 6 Answers
SOURCE: my laptop won't turn on and when I plug in my
This could be a problem with the battery. It's either that or the charger and cables. I would recommend first to replace the charger with a similar one, and replace all cables and see what happens. If not, than you should contact the manufacturer and see if replacing your battery is optional.
Posted on Jan 28, 2010
SOURCE: i have a dell inspiron
take the battery out and try powering on your computer only with the power cord plugged in
if the computer turns on then
this is the problem with the battery
you need to replace the battery
Thank you
Posted on Jan 07, 2011
Testimonial: "thanks. thats worked. will i have to use a dell battery or can a compatible one be found"
My dell inspiron mini 10 wont power up at all with charger and only gives me a brief white light when battery and charger are plugged in. Any suggestions
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 25, 2011 | Dell Inspiron Mini 10 Notebook
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
Computer shutdown like it had no power pluged in charger charger light is on but no power signal on computer
IF the power cord is plugged in and the charger light is flashing or red that there is no power and the power cord is bad.
Feb 06, 2011 | Dell Inspiron 1501 Notebook
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
Probably battery, although that should be orange not red..
Remove battery and try it on AC alone, if that works, it was a damaged battery halting the process
If it does not, check the charger's tightness in the charging port, if sloppy or loose, this will need replacing.
Some Dell's are VERY picky about the charger, if not the exact model specified, they will not charge the battery
If none of the above, remove battery and test with another Dell charger of the same spec, if this also fails to work and you are sure the light is red, you have a problem with the motherboard. Commonly the charger power board fails on these.
Jan 06, 2011 | Dell Inspiron 1545 Notebook
Thank you
Battery alarm flashing orange on dell dell inspiron 6000
flashing because it is very low.
If you charge-it and still flashing it seems to have o problem with battery, charger or even the laptop. Try to test the charger and laptop with another battery and see where is the problem.
Jul 18, 2009 | Dell Inspiron 6000 Notebook
Red Battery light flashes when computer is turned off
The reason the battery indicator would flash is because its reaching the end of its useable life. Meaning that it will become harder for the battery to keeps its charge until it finally doesn't keep a charge at all. best thing to do is when your not using your laptop unhook the charger to it so its not always charging the battery.
To fix the problem though you'll have to get another battery unfortunately.
Jun 02, 2009 | Dell Inspiron B130 Notebook
Red light flashing on far right symbol/battery or charger going ?
May 26, 2009 | Dell Latitude D600 Notebook
Wont turn on
Apr 05, 2008 | Dell Latitude D600 Notebook
Dell Inspiron Mini 10 Notebook Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
