Question about Karcher Garden
Karcher b402 fault finding
Detergent not sucking up
3 Suggested Answers
  • 32 Answers
SOURCE: hello i have a karcher b402 i have had it for a
hi, it sounds like the seals in the pump have gone,
you can repair this your self with some seals, www.karcher.com then click on europe,then international the screen will change.
go to services the spare parts, in put your model.
it will help if you can also find the 8 digit number starting with a 1.something something something dash something something something dot nort.
or ring me on 01729825656
Posted on Jul 04, 2009
  • 34 Answers
SOURCE: hi ive got a karcher
This seems strange, as it is under warranty you can take it back or contact them about the situation. It depends were you purchased the machine but if it is a manufacturers fault they will fix/replace it.
Posted on Jan 17, 2011
Testimonial: "thankyou yes thats what im going to do"
How do I get the detergent hose to suck
There must be static pressure at the reservoir. Try to remove the cap. If it works then the cap will need to vent, i.e. Drill a hole in it.
Jan 06, 2015 | Karcher Garden
Clear hose not sucking up detergent
Check the manual. Bleach eats most plastics and rubber rings. If not flushed well after, the suction will be destroyed.
Jul 30, 2014 | Karcher 330 Pressure Washers
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
Hi ive got a karcher k.3150 ive only had it 2 months and ive gone to use it the 3rd time and the detergent is not coming out of the container and ive done all checks-blockages etc and dont know why its not...
Jan 10, 2011 | Karcher Garden
Cant get my soap dispenser hose working on my karcher winner 10, any suggestion?, lost my instructions manual so dont know weather i need to be doing anything for it!
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to REMOVE the high pressure Sprayer so that all you use is the Trigger Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so you will then need to REATTACH the SPRAYER into the hand gun to work with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just like I did and had a great problem trying to find a link as Karcher doesn't recognize the Model No: as Winner 10 or 11.
Cheers, Luke
Nov 19, 2010 | Karcher Vacuums
I have a Karcher B402 Pressure Washer and when i plug it in and turn it on - nothing happens, not a sound. I have checked the fuse and the plug itself and this did not help. I contacted a service...
hi if you remove the torx screws that hold the electric box on and then bypas the on/off switch join wires together. and check the pressure swicth if it is the pressure switch you can bypass this but the machine wont shut down regards
Jan 19, 2010 | Karcher K2.26 Electric Power Washer
Hello i have a karcher b402 i have had it for a few years it is stating to leak water from underneath allthough not a problem what can i do with this please edwin read
Jun 29, 2009 | Garden
Karcher B402 pressure washer Motor runs as soon as power supply connected, on/off switch does not seem to make a difference and no pressure at outlet? Was working fine, stopped for half an hour, came back...
bob I had this happen to my Karcher, the pressure seals have blown. $Au200 for service and replacement from karcher dealer. tyhey would not sell the parts for a DFY
Jun 22, 2009 | Garden
B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
