Question about Acer Computers & Internet
My Acer is constantly piping up the - Acer Computers & Internet
  • 362 Answers
We will need more info about you problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Feb 18, 2012
Worcester 35cdi overflow problem
if by overflow pipe you mean pressure relief valve either your expansion tank is full and needs to be drained if that type or replaced if bladder type. but if 1.5 bar is normal pres reading then the pressure relief valve is bad (it is a wear item )
Nov 12, 2013 | Heating & Cooling
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
I have been told that my 1999 Cadillac Deville may be experiencing hesitation and rough running because the fuel filter may need to be replaced. Are there any instructions for that?
First we need to check if really fuel filter is at fault for rough running. Open the bonnet and pull out fuel pipe from the engine. Put this pipe in a clean and empty clear bottle (so that you can see the pipe) and now switch on the ignition but do not start the car, just turn it on. See the flow of fuel, if its constant then rough running is due to something else and if your fuel filter is really clogged then petrol flow will not be constant. To change the fuel filter, get under the fuel tank and locate a plastic cylindrical component with two fuel pipe connected to it. This is fuel filter. Buy a new one and replace. Make sure you check the pipes for any fuel leakage after you have connected the new fuel filter.
Aug 17, 2011 | 1999 Cadillac DeVille
Acer screen will not go away
Did you try downloading Windows XP?
Apr 07, 2010 | Acer Veriton 7600GT PC Desktop
My acer travelmate 4150 when switched on makes a constant screaming noise and does not boot up
Try this: once you turn on your Acer Laptop, immediately it shows the acer logo on your screen, press 'Esc" button constantly or press the "Esc" button continuously immediately you turn on your laptop.
I am telling you to do this out of experience, but if it does not work, let me know.
Take care.
Dec 08, 2009 | Acer TravelMate 2300 Notebook
Constant smoke from tail pipe.
If its smoking that bad you should be able to tell if its oil or antifreeze by the smell, stand behind the car as its running, if its white and you smell a sweet smell its antifreeze if its blue and smells like a oil refinery its oil.
Nov 17, 2009 | 2001 Dodge Intrepid
We have a constant smell that won't go away. I
a possible answer is that it is not your drain as such- as there will always be a stink from there - but you may require an 's' bend on your outlet pipe like what would be on your bath or sink this will prevent smells come back up the pipe.
Ihope this is of some use to you.P
Aug 07, 2009 | Dishwashers
Drain pipe under eaves on second story
Yes. You can buy couplings, elbows and pipes at a hardware store and divert the water precisely where you want it to go. Hope this helps.
Sep 11, 2008 | Kenmore 75085 Air Conditioner
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
