Question about Dryers
Randall 102e heating timer,how do you remove the cover without breaking it.
Cover removal
refritech08
  • 149 Answers
SOURCE: Instructions on programming a Randall
here's some links to some pdf files that can assist you
http://www.bhl.co.uk/uploads/article331/Danfoss_CP715.pdf
http://www.plumbnation.co.uk/site/danfoss-randall-102e5--24-hour-gp-mini-programmer/102E5%20Guide.pdf
Hope to be of assistance to you all,
Sincerly, alexander
Posted on Apr 29, 2008
  • 958 Answers
SOURCE: Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Posted on Aug 02, 2008
Matampong
  • 153 Answers
SOURCE: How is the cover removed from the Princeton VL1918
Theres sort of clips that clips to the side of the monitor's frame, use a flat screwdrive to care fully push through the sides of the LCD to unlock the clips.
Posted on Nov 25, 2008
SOURCE: How to remove fan cover
Hi, although mine is currently not working I was able to take the cover off by loosening the six screws that hold the front grill on - the screw heads are visible around the edge of the outer ring.
Good Luck
Keith
PS - there are then four (I think) which fasten the back grill to the motor
Posted on May 09, 2009
philschneide
  • 448 Answers
SOURCE: The interior dome light is burned out, removing cover problem.
You will have to pry off the lens CAREFULLY using a small screwdriver. There are two little plastic protrusions on each long side of the lens which fit into the casement. You can ease the casement away from the lens enough to get it to pop out. Re-inserting it is the same, but probably easier.
Gently, give it a try.
Hope this helps you.
Posted on Oct 23, 2009
Central heating Randall 102e manual instruction
You can down load this from randall web site
Jan 14, 2018 | Heating & Cooling
Randall 102e heating manual
Check the link. You must register, but the manual is free.
http://www.poloniawroclaw.com/randall-102e-user-manual.pdf
Jan 14, 2018 | Cars & Trucks
I NEED INSTRUCTIONS FOR AUTO TIMER SETING RANDALL 102E
Try Googling (RANDALL)(102E)(manual) without parens.
Dec 12, 2017 | Hardware & Accessories
Kenmore Electric Dryer model# 11064672400 doesn't heat up. Repair guy said that the timer is bad and that is the reason that dryer will not dry. Blower and timer seems to be working, just not heating or...
Lets look at that fried timer
A leg on the timer with a big old fat red wire goes down to the heating element. over time the contacts take a beating from the arcing. To test it remove the red wire from the terminal marked RH and clip one lead of an ohmmeter to that terminal. Then check for continuity between that leg and any other terminal on that there timer. if you cannot get a reading. you have a bad timer. Turn the timer knob to various spots on the timer dial to do a thorough test. Onward to today's fabulous timer deal:
You kiddin me $108? That is high even for a fab price. I would do this before buying a new timer.
What can you loose at this point? Remove the timer from the dryer. Take the small shank keeper off the shaft. If it breaks toss it, it ain't nothing but a mechanic stopper anyways. Next remove the 2 screws to the cover and CAREFULLY get that plate off without disturbing the innards. Look for that burn contact and file it down smooth. With any luck ya might get it ta go a while longer. With a price like that the timer ought ta have solid gold contacts. themobilian_520.jpg
Dec 21, 2010 | Kenmore 64732 Electric Dryer
Speaker Removal
the plastic piece should just come right off
Apr 12, 2009 | Car Audio & Video
Trying to remove the user interface cover for a kenmore washer
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Kenmore Washing Machines
Instructions on programming a Randall 102E controler on our central heating system please.
Sincerly, alexander
Apr 29, 2008 | Heating & Cooling
Dryers Logo
98 people viewed this question
Top Dryers Experts
