Acer 5349 Atheros weak signal strength - Computers & Internet
3 Suggested Answers
xrojer
  • 150 Answers
SOURCE: My hcl laptop with winxp
You can try this solution
  1. Right-click on the 'My Computer' icon on your computer and choose 'Properties'.
  2. Click on the 'Hardware' tab and then click on the 'Device Manager'.
  3. Now, find the 'Network Adapters' section and click on the little plus-sign to the left.
  4. Find your wireless network adapter and right-click on it and choose 'Properties'.
  5. This is where things will get different depending on the brand of your laptop and wireless card and which drivers you have installed. Browse through the different tabs and look for settings such as 'Power Management' or 'Transmit Power'. Adjust the settings to either disable the power management or increase the amount of power used by the network card.
  6. Now, test your wireless signal strength to see if you still have the same weak wireless signal you had before. The chances are that you will notice an increased wireless signal strength.
Posted on Jan 17, 2011
Geekman
  • 32281 Answers
SOURCE: Acer Aspire One D250 - Weak network signal
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Dec 26, 2009
Can anyone tell me why all of my BBC digital channels have no signal at night or the early morning, but work again during the day!? thanks
Check the signal strength. If the signal strength is weak, this can happen to digital channels. For analogue channels, the fault due to weak signal will be a grainy picture.
Jul 26, 2014 | Goodmans GTVL32W27HDF 32 in. LCD TV
Acer 5349 restore doesn`t work.
Do you have a question? If you do, try giving us a clue.
Aug 21, 2013 | Acer Aspire Z5600 PC Desktop
Wi-fi connection drops out
Try checking the firewall settings. Try lowering it down.
David
Apr 05, 2013 | Computers & Internet
My acer aspire 5349 Won't Boot at all.
when you boot go into your bios settings and check in your boot section to make sure your hard drive is there and enabled. set it to first in boot order.
Nov 26, 2012 | Acer Aspire 9300-5349 Notebook
Acer aspire 5742Z wireless adapter Atheros AR5B97 intermittent fault loses all local wireless signals. Sometimes can I recover after diagnosing problem - sometimes need to reboot to recover. ??
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 17, 2012 | Acer Computers & Internet
I cant get my Acer 5250-BZ873 to keep a wireless connection
Aug 23, 2012 | Acer Aspire 5100 Notebook
Acer Aspire One D250 - Weak network signal strength with Broadcom 802.11g adaptor
Dec 26, 2009 | Acer Aspire One PC Notebook
Weak signal 60 feet away at neigbhoor's
Some routers just don't put out strong signals. The problems could be wiring in/around/at your house or neighbors....causing weak signal. Are the signal strengths strong in your house?
We have super signal strength on ours upstairs (we have a bi-level house) but downstairs the signal is very low. All the wiring in the house and anything electronic or otherwise can block it.
Hope this helps at least some. Good luck!
Jul 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Computers & Internet Logo
258 people viewed this question
David Payne
David Payne
