Question about Cb900 Motorcycle Security Alarm System Kit Diy
1980 Honda CB900 custom won't start.
I've replaced the gas and it seems to want to fire with ether but won't start. I may have the plug wires in the wrong firing order but I'm not sure. Any suggestions? Thank you.
  • 2336 Answers
SOURCE: not runing
switch plug wires and see if the dead cylinder starts firing --if it does you need new wires
Posted on Nov 10, 2008
  • 52 Answers
SOURCE: Getting my bike started
The # 1 cyl is on the left side as you are sitting on the bike. Firing order does not really apply to these motors as the coils fire twice per cyl. The left coil will fire 1 & 4 the right coil will fire 2 & 3. I usually hook them up as follows: Left outer to #1, Left inner to #4, Right inner to #2, and Right outer to #3
Here is a good site on XJ's
http://www.geocities.com/MotorCity/Speedway/7795/xjfaqbig.html
I hope this helps
Posted on Apr 08, 2009
Benimur
  • 6966 Answers
Hi and welcome to FixYa,
The connection to the ignition coils would be as rdgrnr posted; seated on the bike, left ignition coil wired to extreme left and right cylinders while right ignition coil goes to the 2 cylinders at the center. Firing order on would be 1 3 4 2 but that would be essential to the valve openings and not on the spark. The design of these bikes has a wasted spark (again as rdgrnr has likewise noted).
I had the 750 version and it is not different.
Good luck and thank you for using FixYa.
Posted on Apr 10, 2009
bozcro
  • 867 Answers
SOURCE: hey guys i'm lost i bought a 04 r1 they said it
is the spark nice and blue? if orange, coil is weak and needs to be replaced.
Posted on Aug 08, 2009
  • 32 Answers
SOURCE: 91 honda accord lx no fire replaced distrubutor
i am thinking that the 15 amp fuse is the fuse that protects the ecm circuit replase the O2 sensor wires and check the harnes for a shorted wire.
Posted on Oct 03, 2009
Hi there I've got a 05 polaris predator 500 Tory
hi try cleaning the carb or check your air filter box might be filled with oil so all you have to do is clean the air filter out with water let it dry and soak all the oil up with a rag or sponge. Best of luck!
Aug 28, 2013 | Garden
Truck is not firing on 3 cylinders yet it runs.. Runs really rough, back fires, under powered.. Plugs are Wet, Firing order is correct. New Spark plug cables. Don't know that is wrong! Please Help
Check for spark at the plug ( may have coil problem).
If spark is good then do a compression check. Pressure shouldn't be less than 75% of known good cylinders.
Apr 17, 2013 | 1995 Dodge Dakota
1993 Mazda MX-3 won't start
Check for spark at the sparkplug, to see if everything in the dist. is working right. And check the injector harness for something being pulled loose when the wires were jerked out.
Oct 17, 2012 | Cars & Trucks
I cant get the spark plug wires back on the way they came off and it won't start
Your factory motor is the 3800 V-6 for your model. You can get the firing order from your local parts store...(Auto Zone will print this for you for free) then you just need to identify the #1 cylinder spark plug and follow the firing order...if you have a friend with the GM 3800 V-6 (popular GM motor) you can also compare the firing order (plug wires) Hope this helps.
Mar 29, 2012 | 1994 Oldsmobile 88
Firing order for a 1994 chevrolet s-10 blazer 4.3 vortec engine vin code w
firing order is 1-6-5-4-3-2... the driver side is 1 3 5 and the passenger side is 2 4 6
May 25, 2011 | Chevrolet S 10 Cars & Trucks
Cb900 Motorcycle Security Alarm System Kit Diy Logo
146 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Spud Howell
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
