Question about Microsoft Windows Vista Ultimate Edition
0x409 startup repair cannot repair this computerautomatically
Hi, befor i install window 7 my laptop running window vista now istall window 7 geniune 7600 build i want update update driver but show the screen victim of software counterfeiter please help me how to...
Buy the license first.
Download Key Update Tool, a utility provided by Microsoft to change the key of the Windows version installed.
The download address is http://go.microsoft.com/fwlink/?LinkId=50346&clcid=0x409
Double-click the utility will then check the system files.
Enter the official key and click Next.
Accept the license agreement and click Next.
The key is legalized.
Click Finish.
Windows restarts.
Jan 02, 2011 | Microsoft Windows XP Professional for PC
Install software for vista premium for my mn-100 router
router do not require software unless this is a usb version.
Jun 07, 2008 | Microsoft Broadband Networking MN-100...
My Dell Inspiron 1501 laptop screen suddenly went black when I was using the laptop.It went completely dead. I have tried connection the adapter to a different power outlet, disconnected and reconnected...
Follow the below steps it would fix your issue.
Method 1: First you need to try safe mode and check if you are able to boot to the desktop.
Follow this below provided link to start your computer in safe mode.
Advanced startup options including safe mode
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
Method 2:
If you are able to boot into safe mode then in order to troubleshoot this issue further, you may unplug all the external devices except keyboard and mouse and check if you are able to boot to the desktop.
Method 3: If the above provided steps don't resolve the issue then, I would recommend you perform startup repair.
Follow these steps:
To perform a Startup Repair follow the steps below:
a. Please insert the Windows 7 DVD and reboot the computer.
b. When we are prompted to press a key to boot from the DVD, please press Enter or the space bar.
c. Choose your language settings, and then click Next.
d. Click Repair your computer.
e. Select the operating system you want to repair, and then click Next.
f. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Access the link below for more information about startup repair:Startup Repair: frequently asked questions
http://windows.microsoft.com/en-US/windows7/Startup-Repair-frequently-asked-questions
Dec 25, 2010 | Dell Inspiron 1501 Notebook
What should i do if my laptop doesn't start and recommends launch start up repair?
If so then launch a startup repair. This problem is because when the system suddenly powered off . Its good to launch a startup repair... This will fix the startup problems
May 06, 2010 | HP Compaq Presario C700T
Startup repair cannot repair computer automatically
insert the windows installer on the disk drive then repair the windows.
Apr 10, 2010 | Compaq Presario 700 470024-192 Notebook
Enter password
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!!
Note -- If your computer cannot boot into Vista even after repairs, then go back to System Recovery Options and run System Restore.
That's it! This is how you use Startup Repair for most unbootable situations.
Feb 22, 2009 | Acer Aspire 3680 Laptop
Will not turn on, last time used, I turned it off manually?
Try this:
Feb 22, 2009 | HP Pavilion DV6500T Notebook
Computer windows will not come up
Try This:
Feb 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
Jan 05, 2009 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
148 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
