Question about Euro-Pro NV31 Infinity Vacuum
I thought I was buying a manual. I put a new belt on my vacumn but it makes a funny noise and does not leave vacumn lines on the carpet like it used. I don't know if it takes two belts or one.Wish I had a manual.
    Genius:
  • 1,739 Answers
Hi Frrank: The Owner's Manual for the Euro-Pro Infinity NV31N Vacuum can be downloaded in PDF from the following site:
http://dl.owneriq.net/d/df6c4a72-cf05-7934-2963-ee752eb0e124.pdf
See pages 15 and 16 of the PDF for instruction on replacing the single belt.
If this is not the manual for your model, please reply and will try again.
Thank you for using FixYa!
Posted on Feb 18, 2012
Shark nv350 making loud noise when switched for carpet
HI, it's Jim from Crucial Vacuum!
If your Shark NV350 vacuum is making loud noises when switched to carpet then there are a few parts of your vacuum you can check to resolve the problem.
First thing let's check your vacuums canister. The idea is to prevent clogs and anything that will obstruct your vacuum from operating properly, and running smoothly without noise. You'll want to empty your canister after every use.
Secondly, let's check out your brush roll. Is there hair wrapped around the roll itself, or any noticeable debris that would prevent the brush roll from turning? If so remove it and manually rotate the brush roll to help unearth any hidden clogs behind the roll.
While you're examining your vacuums brush roll take a look at the belt as well. If the belt isn't wrapped around the brush roll properly this could be causing the noise. The belt should have a good bit of tension on it in order for the brush roll to turn properly. Your vacuums belt should be replaced roughly every 3 months. So be sure it's on properly and has a good bit of tension.
You can purchase replacement parts for your Shark NV350 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV350&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim
Crucial Vacuum Customer Care
Mar 19, 2015 | Shark Navigator Lift-Away NV350
Noise
Hi Linda,
Sounds like clutch problems, try to move the lever for carpet/floor back and forth a few times maybe it will free up. If it still makes the grinding noise, the clutch assembly will have to be replaced. Let me know, i can even walk you through the repair if needed.
Apr 08, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Makes ratcheting noice when put into carpet
Cog belt is slipping, could be debris on the pulley or bad belt or cog wheel....
Feb 15, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do I put an new belt on this vacumn cleaner?
Surprising though it may seem, that will depend on what make and model of vacuum cleaner you've got. Instructions will be in your user manual (if you no longer have the manual you can usually download a copy from the maker's website).
Jan 13, 2010 | Vacuums
The brush will not turn. It makes a grinding
It might be that the drive belt is stretched, broken or worn. It can cause the brush to not turn and it will make funny noises. I would try changing the belt. You can get a replacement here:
Dyson DC17 Belt
Nov 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My vacuum makes a loud noise like a soccer horn going off, and neighbors are yelling at me for it! how do i make it quiet? its a bissel.
If you haven't changed the belt recently I would try that. Worn belts can cause funny noises sometimes. You can get Bissell replacement belts here:
www.bissellbelts.com
Oct 28, 2009 | Vacuums
Not as strong when bought, weird noises too.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618616&thid=682390
Posted by Swork100 on Jun 18, 2008
The main problem is a weird noise caused by the brush not spinning on the carpet like it used to do strongly leaving a sweep mark on the carpet, which helps pick up the dust through suction. Seems to have lost the power, so I raised it, but it still doesn't pick up that well. What should I do, I already checked the belt, ripped all linen spinned on the brush. It just doesn't leave that mark on the carpet after being swept, it just stops. What should I do? Dirt Devil Featherlite Bagless Vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of the problems you seem to be having is that the belt is stretched out and not picking up well and the other is the brushroll is not spinning freely in order to pup the dust and dirt. The average flat belt change is every 4 to 6 months for the best cleaning and the check your brushroll to see if that spins freely if not it is probably bound up with thread and hair and needs to be cleaned off @ every belt change. If the belt is tight it cleans well and the brushroll does not get a chance to wrap around the brushroll and slow it down. All part of the maintenance of a vacuum cleaner. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 18, 2008 | Dirt Devil Featherlite Bagless Vacuum...
Suden loud noise when vacuming carpet
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Nov 11, 2007 | Dyson DC14 Full Access Bagless Upright...
Brush roll slows/stops turning
when you removed the beater brush did you clean all the lint and threads off the ends of the brush? you can unscrew one end of the beater brush plate to clean the crap off it. Inside the beater brush are two ball bearings. Use a light machine oil to lube these two bearings. re-assemble the rod and end nut. then put your brush back in the machine and note which direction the belt needs to be installed. there'll be an arrow on the motor housing.
Sep 05, 2007 | Kirby G4 Bagged Upright Vacuum
Euro-Pro NV31 Infinity Vacuum Logo
57 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
