Question about Sentry Fireproof Safe
I have a sentry 3100 lost the combination s/n # 100179 help me please ?
SOURCE: sentry safe V530
Send a notarized letter stating you are the owner of the safe with the serial number and a $8.00 money order to
Sentry Group
Attn: Dept 200,882 Linden Ave
Rochester N.Y. 14625-2784
Posted on Oct 23, 2007
dmathwizard
  • 113 Answers
SOURCE: lost combination to sentry 3100
You have to contact Sentry directly to get the combination
Sentry Safe
1-800-828-1438
www.sentrysafe.com
Posted on Mar 05, 2008
SOURCE: sentry 3100 safe_i remember combination but do not remember which way to turn
go around 3 times to the left
stop at the 1st number
go to the left one full time and pass the # but stop at the 2nd #
go to the right and stop at the 3rd # the 1st time you come to it
I just bought one last night
Posted on Sep 13, 2008
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: lost codes
would you know the factory recovery code for sentry 1610 as
i lost it or it is locked in my safe. My battery has been dead
for some time and I think it lost it's memory.
Posted on Jul 30, 2009
Lost combination ..how to open
How to crack sentry safe, Lost safe combination - YouTube
? 5:43
https://www.youtube.com/watch?v=UdMun9qBgFo
Sep 25, 2012 - Uploaded by George Serrano
Lost safe combination Sentry Safe m# DS0100 Cracked! Still usable.
' Sentry® Safe ' DS3431 Combination FIRE-SAFE®
Dec 28, 2015 | Sentry FIRE-SAFE Combination Safe DS3431,...
What is the code in enterfactory
Hi.
Hi. There is no factory fixed code. Thieves would be the first to benefit from such feature! The factory code is uniquely associated to the safe serial number and it is stored in Sentry protected database. When original code is lost the only way to unlock the safe is bay following Sentry's procedure.
Contact Sentry immediately. They will first try an emergency unlock code, and then they will give you instructions in case the safe must be serviced. Here the contact: Call or Email Us
Here general instructions about what to do when combination does not work. Instructions are addressing lost combination.The procedure is the same in all cases when combination does not work (malfunctions, lost combination etc.) . Please contact sentry and follow procedure to get the safe open.
Regards.
Ginko
Oct 05, 2011 | Sentry Fireproof Safe
I have a sentry 3100 safe but forget the combination and cant open it
You will have to contact sentry and give them the details, they will probably ask for proof of purchase as well.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | Sentry Fireproof Safe
We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Dec 07, 2010 | Sentry Fireproof Safe
Lost combination to sentry 1270
Hi.
If you have lost the combination you need to follow detailed procedure needed to retrieve the key from Sentry.
Please follow the instructions detailed in this link.
Regards.
Ginko.
Sep 23, 2010 | Schylling Combination Steel Safe
Lost Combination to SL500 sentry safe
If you need your combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination:
Apr 30, 2010 | Sentry Fireproof Safe
Lost my combination to my sentry safe co.
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination:
Feb 21, 2010 | Sentry Fireproof Safe
I lost the combination to my sentry safe serial numbers 4895857 had it for 10 year geting kida old can you help
Sentry Safe lost combination. First, find your Sentry Safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
Jan 29, 2010 | Sentry Fireproof Safe
Lost combination for Sentry 1250
Lost your sentry safe combination. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. sentry safe lost combination and the opening instructions.
Nov 16, 2008 | Sentry Fireproof Safe
Lost combination to sentry 3100
Sentry Safe
1-800-828-1438
www.sentrysafe.com
Feb 11, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
201 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
