Question about Epson Perfection V700 PHOTO Flatbed Scanner
Any calibration to perform on v700 scanner - Epson Perfection V700 PHOTO Flatbed Scanner
  • GuyN Feb 19, 2012
    Hi FixYa Team,
    Although both locking mechanism on the V700 scanner are unlocked, the V700 is presently making a loud grinding/clicking/clashing noise during the scans of negatives.
    No problem or noise in scanning photo, it is just the top carriage scanner for negatives that is starting this noise once crossing 2.3" of the scanning area in the preview of the professional mode.
    Do you think I am facing a mechanical problem, and I am wondering if any alignment or calibration can be done, or any other idea on what to do beside returning to Epson. Actually I have made two experiment:
    1) doing a preview scan and let it go to the end with all the noise and than selecting an area of scan W-8" and H=2.3" and then scanning effectively - no noise during this short scan as it did not cross the area line of (H=2.3")
    2) repeating 1) for the preview scan but pulling out the connector of the top cover of the scanner connecting to the base. The preview will take time but will scan with no noise as the Top part is not activated although the preview is set for negatives.
    Hoping that you will be able to help and suggest, thank you
    Guy
When I turn on the Epson v700 scanner, only the little blue light on top blinks but the scanner will not fully turn on and it makes no sounds. It was working fine a few days ago. I never had any problems...
Hi..
If the drive icon is displaying on My Computers then nothing to worry.. if not check all cables or reinstall the drivers. if still it persists go for repair...
Apr 05, 2014 | Epson Perfection V700 PHOTO Flatbed...
Scanning 110 Instamatic slides on Epson Perfection V700 photo scanner
Hi Stanley - does this youtube video help? http://www.youtube.com/watch?v=EcALdbbCnSk
If not, let me know and we can investigate further.
Regards,
Justin.
Jan 17, 2014 | Epson Perfection V700 PHOTO Flatbed...
I am using the Epson Perfection V700 photo scanner to scan dental xrays. Sometimes the xrays come out perfect, other times I get streaks across the image. Sometimes the streaks are colored, othertimes...
You have to use the "FILM AREA GUIDE" included with the scanner. This black plastic guide leaves a small area at the top of the glass open so that the scanner can calibrate itself at the start of each scan. Use the guide or leave at least 8mm between the top of your film and the top of the scanner glass.
Jan 24, 2011 | Epson Perfection V700 PHOTO Flatbed...
Does the soft ware in the V700 support early colour negative material ? I can find Ilford HP5 but not Ilfocolour !
There isn't a specific template for that film, but you can try out with generic settings and see how it goes. I rarely use the specific film settings from scanner software, and always prefer to adjust them to each roll I scan. Good luck with that! :)
Jul 09, 2010 | Epson Perfection V700 PHOTO Flatbed...
I have an Epson Perfection V700 Photo scanner and an Imac version 10.5.8. Are these compatable?
Yes the scanner is compatible with a downloaded driver from epson. however some of the supplied third party software may not be. Also with MACS the push button scan may not work.
Dec 28, 2009 | Epson Perfection V700 PHOTO Flatbed...
Red light flashing on power button after attempting a scan, making a funny jerky sound like a jammed mechanism
Found online epson manual, found that lock tab on the back of the scanner had been bumped across to "lock" position.
Jun 18, 2009 | Epson Perfection V700 PHOTO Flatbed...
Epson V700 - in the home mode rotate button has vanished
Try to do a reset all. Click on configuration, then click on others and click on the reset all button.
You may need to trash and re-install the twain driver. Please log on to epson.com to get the proper driver for your scanner compatible with your operating system.
Apr 28, 2009 | Epson Perfection V700 PHOTO Flatbed...
When I scan colour slides the image gets cropped
Uncheck the option that says "Thumbnail" and draw individual marquees for the area on the slide you want to scan. Not very elegant but it works.
Dec 31, 2008 | Epson Perfection V700 PHOTO Flatbed...
Epson Perfection V700 PHOTO Flatbed Scanner Logo
64 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
