Question about Samsung HT-Z310T Theater System
Protect after turning on the dvd player protect comes across the led then turns off
  • herefords Nov 14, 2008
    I turn the system on, then the word protection rolls across the screen and it shuts off. I have a Samsung DVD home theater system ht-d8600.
  • Samsung Master
  • 19,396 Answers
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
My Westinghouse TV LCD has no sound but has picture please help? 42 LED westinghouse..I CAN PLUG IN THE DVD PLAYER AND IT HAS SOUND! please help!
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 06, 2014 | Westinghouse Televison & Video
When I turn the DVD player on it says "protection" on the screen and automatically shuts off. Can I fix this myself?
WHEN YOU TURN ON YOURN DVD PLAYER USE THE REMOTE AND PRESS MENU THEN GO TO STTINGS THEN SECURITY SETTING THEN REMOVE PROTECTION
Jan 17, 2013 | Televison & Video
Dvd player keeps turning its self on
What brand/model #? It could be that it is in demo mode, and scrolls info across the display. Should be able to turn off demo in the setup menu somewhere if that's what it is.
Jan 10, 2013 | Televison & Video
I need the code for a ge dvd player my remote is a ge jc021
The codes are, 403,409,430,0409,0430, Step 1. Turn on DVD, STEP 2. Press and hold the CODE SEARCH or SETUP button until the LED light comes on,then release it. 3. Press and release the DVD button, the LED will blink and remain on, 4. enter one of the three or four digit code, the LED will go off, 5. aim the remote at the DVD and press the POWER button,the DVD should turn off, if not try steps 1-5 again using a different code.....hope this helps...
May 20, 2010 | Universal Remote Control GE174Universal...
Toshiba sd-kt50 dvd player turn on open/close hello appears protection appears and goodbye comes up turns it self off. we had two second power offs not associated with a storm
the sudden power cut-off can either blow the fuse or corrupt the system of DVDs.but, some DVDs has protection for this occurrence.try not to use it for sometime.then if it's well rested try turning it on see if is resets it's protection circuit.if not, a new unit or call a technician for it.
May 07, 2009 | Televison & Video
I have a samsung DVD Home Theater System HT-WX70. My son put a cd copy in the DVD player and PROTECTION flashed on the player and it turned off. I turned the player back on and took the cd out. ...
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Nov 18, 2008 | Samsung Televison & Video
Protection mode
the protection feature is for shock protection and will go off if one of the speaker's positive and negative wires are touching check your wiring
Nov 11, 2008 | Samsung HT-SK5 System
Some sort of box across the screen
Try to look at your captions on your tv...you probbally have them set on text 1 or 2 which cause the box to pop up also why it goes away when you push a button. Turn all caption functions of your tv off...cc and text this should take care of the problem.
Feb 05, 2008 | Panasonic DVD-S27 DVD Player
DVD turns off with "Protection" message.
it may be becoz you are using too many things from 1 plug socket / power adapter.
Aug 14, 2007 | Samsung HT-DS1000 System
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
Samsung HT-Z310T Theater System Logo
609 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
