Question about HP Compaq nx6310 Notebook
Sensitive mousepad can i adjust the sensitivity
    Sergeant:
  • 167 Answers
Do this
start,control panel,mouse,button and then slow the speed of double click
Posted on Feb 17, 2012
3 Suggested Answers
  • 196 Answers
SOURCE: Is it possible to adjust
no there is not a sensitivity setting for the spacebars, however, some people have eaten or trimmed their fingernails and so on by their computers and in turn have gunk stuck up underneith the keys.
So check to make sure something has not landed up underneith it and clean it out if it has.
and make sure the keyboard is seated correctly. (if other keys dont work or don't work well this is a sign that the keyboard connectors are not seated correctly, but if all other keys work fine it is not a seating issiue and your cables are connected just fine.) If under warranty call the HP techs first!
otherwise http://h10032.www1.hp.com/ctg/Manual/c01918142.pdf
Page 70 will get you to the techs maual on keyboard removal, cleaning and so on. a dry toothbrush and a vacume will go a long way though....
Posted on Apr 30, 2011
  • 61 Answers
SOURCE: How do you adjust the sensitivity of an ALPS
You may very well find you ALPS driver installed on the laptop in question doesn't have a sensitivity setting.
In that case you can try locating this driver:
ALPS Touchpad Driver 7.2.302.105
I know it can be found on "www.softpedia.com".
Installing it may resolve your problem as it updates the lack of sensitivity settings in older ALPS drivers for touchpads that have the capability to discern the level of pressure being applied to them.
Posted on Feb 04, 2010
How do you stop the cursor from jumping on an elitebook folio 9470m
go to control panel / mouse to open the mouse properties window. along the top of the window should be several tabs. select the tab for touchpad or maybe advanced properties. this tab allows you to adjust the touch sensitivity of the mousepad, momentum, and other properties. adjusting to make it less sensitive may reduce the tendency of the cursor to jump or move on its own. failing that, go for an external mouse!
Aug 14, 2014 | HP EliteBook Folio 9470m 14in LED...
Text writing is weird. I write and part of the word appears a sentence away?
Ha, it's because your wrist or thumb is touching the mousepad occasionally - some are more sensitive than others.
Try turning the mousepad off while typing, sometimes there is a button at the mousepad area, others it's an Alt-Function key. Look for a symbol on the F-keys that look like a finger touching a square or mousepad. This, and the Alt key combination will shut it off and then back on again when you select them.
An external or USB keyboard and mouse works great for me.
May 08, 2014 | Computers & Internet
The mousepad is very sticky or something is getting activated without touching, how can I solved this? thank you#
go to control panel and then go to touch pad setting then u find the sensitive ness setting adjust according to u
Oct 25, 2013 | Toshiba Satellite Computers & Internet
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
When typing, cursor jumps backward several spaces
Sounds like your mousepad is ghosting. This means it thinks you're tapping the mousepad as you type, which will make it type exactly where you nlast moved the curser to. First, try cleaning the pad thoroughly with a damp tissue, and dry it well... if that doesn't solve it, you could try adjusting the mousepad sensitivity controls on the control panel. Hope that helps.
Oct 10, 2012 | Acer Aspire 5733Z-4633
Slow mouse on any surface
Go to the mouse option in the control panel and adjust your mouse speed and sensitivity.
May 07, 2010 | Logitech Cordless Mouse
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
Speed strip on touch mouse is too sensitive
remove the touch pad software if u have any installed for the touch mousepad
Nov 24, 2008 | Computers & Internet
Mouse is jumpy on new mousepad
You can adjust the sensitivity of your mouse.
Go to Control Panel>Click on Mouse>Lower the slider bar
Try again and see if it works any better.
Sep 03, 2008 | Logitech Cordless Desktop MX3200 Laser...
HP Compaq nx6310 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
