Question about Memorex MP3225 Cassette/CD Boombox
Cassette player shuts off power
When I press "play" on the cassette player, the entire machine powers off. I can power it up again and play the radio or CD player, but pressing play, FF or rew makes the machine shut down. I can't even think of any reason why this might be, except some short or something deep in the innards. Any suggestions?
2 Suggested Answers
  • 357 Answers
SOURCE: cassette player doesnt play or record, ff or
If you hear a faint whirring sound from the cassette player while performing these functions, the motor is fine, but you require a new drive belt/s that need to be fitted at an electronics shop. If you hear not sound at all, the motor has died (possibly belts too), again it will require and electrinics repair shop visit.
For the sake of repairing it, it maybe cheaper to buy a new one.
Posted on Jan 14, 2011
How to add an iPod Input into a Stock Radio?
<p>You can add an iPod to a stock radio in your car, even if the plant does not have an auxiliary input or iPod input using a specific number of iPod car accessories. One such accessory is a cassette adapter that plugs into your iPod as a headset, but ends on a cassette tape to your stock cassette radio. However, not all cars have cassette players, thus more accessible to the FM transmitter. <br /> <p><br /> <p>1. Connect your iPod to an FM transmitter, if you connect headphones to the iPod. <br /> <p><br /> <p>2. Connect the FM transmitter to your cigarette lighter to power and then to the transmitter. <br /> <p><br /> <p>3. Press up and down on the transmitter to the FM transmitter to change, you will pass the signal to your radio. Choose a station that is not a radio station on it so you do not interrupt the signal. <br /> <p><br /> <p>4. Set your stock radio to the channel you selected on your transmitter and then play the songs on your iPod. You will see the songs on your iPod through the radio station you selected. <br />
on Aug 09, 2011 | Apple iPod touch
How do I play cds on my Philips portable stereo with the message 'door open'?
It could be caused by a small contact switch inside that has either broken or is stuck in the door open mode.
Oct 18, 2017 | Audio Players & Recorders
My cassetteplayeris broke but the front panel says tape unpluged it radio won't play pluged it back in few days later tharadio came back on.going down the road it swithched from radio playing back to tape...
the cage mechanism of the cassete is dropping causing it to shut the radio off ,only solution is to remove the radio and open case then jam the cage into the no casette position with a piece of wood or a folded up cardboard ,i think this will cure the problem
Feb 15, 2011 | Car Audio & Video
I have a TDK HD-01 head demagnetizer for cassette decks, but I have lost the instructions. Could you help?
Hi there.
First - Turn On The Tape Demagnatiser (should be a switch on it)
Second - Insert into cassette player
Third - Turn On cassette player
Fifth - Press Play on cassette player
Sixth - After 10 seconds press stop on the cassette player
Seventh - Remove the cassette demagnetizer from the cassette player
Eighth - Turn off the demagnetizer and put back in it's usual storage place
Jan 07, 2011 | Audio Players & Recorders
My delphi roady plays through cassette adaptor. Volume is very low even when audio level is moved all the way up. ???
You need to cycle back through after puttung the cassette in. Mine did that (before the cassette feature stopped working altogether) and I would press my "source" button so it would go from the cassette to the radio, then CD and back to the cassette - the sound would be back to normal again.
Oct 06, 2009 | Delphi Roady XT XM Radio Receiver
Will not display picture or eject tape.
most of no signal means dsr 11 or similar machines have dirty heads. When they get dirt sometimes, you can´t play a cassette and the machine turns off (with the cassette in).
I´ve tried several times to reload the cassette and I manage to make it work again.
with the cassette in and the machine off press at the same time power and fast forward.
When in fast forward press play and your head should be starting to be clean (takes 4 o 5 minutes
to get a clean picture). Normally the machine gives a code error like if it was a loading problem but
not nearly related
Mar 13, 2009 | Panasonic Televison & Video
My cassette player will not play the radio...
it sound like you fried the radio by taking the fuse out of the system that fuse was blowing for a reason power wire maybe grounding somewher check the power wire with a meter good luck.
Jan 05, 2009 | Blaupunkt Hollywood C30
RCA Boom Box, Cassette Player works improperly
This sounds like a dirty or sticky pinch roller - use a commercial cassette head cleaner - or ear but with a alcohol cleaner -
If the capston is not rolling the cassette forward this my be due to a broken belt - or may have just jumped off - power down the product and disconnet from the mains - then open it up - normaly the front come away undo the mounting screws from around the cassette mechanism normaly around 4 and carefuly look at the back there should normaly be 2 rubber band one to the capston and 1 to the pich roller the belt that may be broken is the smaller of the too. most cassette deck use the same size belt
Feb 09, 2008 | RCA AM/FM Stereo Cassette Recorder...
RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Dec 03, 2007 | Audio Players & Recorders
Memorex MP3225 Cassette/CD Boombox Logo
24 people viewed this question
Top Memorex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
