Question about Calculated Industries Qualifier Plus IIIfx Desktop 43430 Calculator
Where is the shift key on the aurora pr680 calculator
How do u do fractions on the caluator
Look for a key marked [a b/c]. Its shifted function will be [d/c].
Separate the different components of a fraction or mixed number with a press on the [a b/c] key.
Aug 19, 2014 | Aurora Electronics SC190 Scientific...
How are numbers in scientific notation entered in Aurora SC150X calculator
Look for a key that is marked EE, or Exp, or x10^x. To enter a number in scientific notation, you enter the decimal part, then press the Enter Exponent key, followed by the exponent. If exponent is negative, you precede it with a press of the change sign key (-).
Once a number is entered there is no special treatment: multiply it divide, or add it.
Mar 16, 2012 | Aurora Electronics SC150X Scientific...
I need to know how to turn off the round up function on the aurora PR680 calculator
Hello
You have this post in the Car and Truck product category, if you wish to have the right expert look at your problem you will need to post the problem in the correct category. Thanks
Feb 17, 2012 | Cars & Trucks
I cant figure out what is the shift key on my calculator. I have a Sharp EL-531W. I tried the 2NDF key and its not coming out right.
Regardless, that is the markings on the SHIFT key on Sharp Calculators. The 2ndF key accesses the functions that are marked on the face of the calculator, not on the top of the keys.
Sep 16, 2011 | Sharp EL-531VB Calculator
Where is the "shift" key
The shift key is usually a yellow button on the calculator. Located at the top left of the calculator. The exponent key can be substituted like this.... ^ 4... The carrot key is should be on your calculator. put the carrot key and then the number after wards and that will make you your exponent
May 12, 2011 | Texas Instruments TI-30XA Calculator
I want to calculate powers on my calculator but am unsure what buttons to press
You have two buttons to calculate powers: The [x^2] calculates the square of a number while the [caret ^] key allows you to calculate any power, be it with integer, fraction or negative exponent.
Both keys are next to one another, one below OPTN and the other below the VARS key.
To calculate roots, you have the square root [SHIFT][x^2] the xroot key [SHIFT] [caret ^] , the CUBE root [SHIFT] [(] , and the inverse key [SHIFT][).
Feb 28, 2011 | Casio FX9750GII Graphic Calculator
How to use calculator on how to evaluate trigonometric functions
The FX-115ES is somewhat different to other calculators you might know. The sequence of keys is more like writing up a calculation in a textbook, whereas for "normal" calculators operations are reversed in some places.
For example, with most calculators you would type 30 [sin] to calculate the sine function of 30 degrees, with the 115ES its [sin] 30 [=].
The 115ES has all the standard trigonometric functions:
  • Standard functions (sin, cos, tan), type the [sin], [cos] or [tan] key followed by the argument.
  • Inverse trigonometric (sin?¹, cos?¹, tan?¹), type [SHIFT][sin], [SHIFT][cos] or [SHIFT][tan] followed by the argument.
  • Hyperbolic functions (sinh, cosh, tanh), type [HYP][sin], [HYP][cos], or [HYP][tan] followed by the argument.
  • and finally inverse hyperbolic (sinh?¹, cosh?¹, tanh?¹), its [SHIFT][HYP][sin], [SHIFT][HYP][cos], or [SHIFT][HYP][tan] followed by the argument.
Arguments can be given as numbers with mantissa (2.718), as fractions (use the fraction key below [CALC]) or as degree, minute, second (30°12'45") using the [°'"] key for input. To switch between degrees (1 circle = 360°), radians (1 circle = 2?), or grad (1 circle = 400 gon), use [SHIFT][DRG>].
Jan 06, 2011 | Casio FX-115ES Scientific Calculator
How can i get the shift of sine, cosine, and tangent in my calculator?
I am not sure what you mean, because your question already shows what you have to do.
To use the functions marked on the body of the calculator you use either the SHIFT key for the ALPHA key.
If a key has next to it (on the body of the calculator) two markings, the one on the left is accessed with SHIFT, and the one on the right with ALPHA. Colors of commands on calculator body are coordinated with the colors of the Shift key and the ALPHA key.
The question I am asking is whether you know what [SHIFT][COS] means. You probably do, but just in case you do not (no reflexion on your abilities)
[SHIFT] [COS] gives access to the arc cosine function, [SHIFT][SIN] the arc sine function, and [SHIFT][TAN] the arctangent.
May 04, 2010 | Casio FX-115ES Scientific Calculator
Dividing numbers
Turn the calculator off. Hold down the shift key and then turn on. "Shift" should dispay on the screen. Now press the memory button with "5/4" on it. You can choose between "cut", "up" and "5/4".
Jul 12, 2008 | Aurora Electronics PR600 Calculator
Lost my manual
http://www.aurora-ltd.co.uk/OpInst/CSM.htm
Jan 07, 2006 | Aurora Electronics HC212 Calculator
Calculated Industries Qualifier Plus IIIfx Desktop 43430 Calculator Logo
22 people viewed this question
Top Calculated Industries Office Equipment & Supplies Experts
k24674
Vernon Taylor
Joe Garcia
Joe Garcia
Are you a Calculated Industries Office Equipment and Supply Expert? Answer questions, earn points and help others
