Why does my potterton netaheat profile boiler takes 20 goes to fire up main burner
  • Heating & Co... Master
  • 2,900 Answers
I t could be a weak spark on the electrode , or the electrode is cracked
could need a clean , bad connection to the electrode , any of these .
It mat well need a service.
Posted on Feb 18, 2012
SOURCE: I have a Potterton Prima F50 boiler and it fires
Don't have a problem
Posted on Nov 26, 2009
heatman101
  • 43501 Answers
SOURCE: Hi. We recently moved to a rented property. We
You definetly have a control issue. However trying to diagnose the exact problems that you have would be very difficult without actually seeing the wiring. You defintely have a wiring/control issue but I cannot tell you exactly what it is without more info. Sorry, I would love to help you more...
Posted on Nov 13, 2009
  • 2900 Answers
SOURCE: hi, my ideal combi boiler model mini HE C28 goes
Hi check the flame senser is in postion and clean
Posted on Feb 01, 2010
SOURCE: potterton statesman utility boiler making
Hi my boiler has just started to do the same. Have you had yours fixed and do you know what the cause was and how the problem was solved?
Thanks for a reply
Posted on Feb 28, 2010
SOURCE: boiler cuts off after abt 20 secs of igniting,hot
Yes usually it is indeed the thermostat, or Thermistor, all part of the control circuit. You did not indicate what type of setup you have. I suggest you Google for a thing called a service manual. This will aid in diagnosis, and repair of your system.
Posted on Mar 29, 2010
Testimonial: "cheers ,i the themister the same as a thermostadt ,"
Hi i have a potterton netaheat profile 50 pilot is lite but main burner will not can u help please ?
There is a black reset button underneath the boiler, a safety over heat button, try resetting it if the pump has no flow restrictions, then most likely the over heat stat is failing.
Jan 06, 2015 | Heating & Cooling
Hi. We have a potterton netaheat profile boiler and the pressure has dropped so low nothing will work. I know it needs to be recharged but don't know how to do it. The only visible pipes are on the top...
The cold water feed to the boiler is where you will find the refill point which should be at the base of the boiler where all the pipes come in
Oct 06, 2017 | Water Heaters
Need Manual
Try the baxi potterton wedsite you can down load manuals there or they have at tech line
Nov 24, 2012 | Heating & Cooling
Require a manual for a potterton profile gas boiler
Go to the potterton Baxi wed site you can down load them there
Sep 20, 2012 | Heating & Cooling
Potterton profile not firing
did you bleed the pump as well
Jun 09, 2012 | Heating & Cooling
Ihave an old potterton netaheat 6/10 the pilot will light but main valve won,t open it was working fine until we had several power cuts any ideas thanks
Sounds like your gas solenoid has failed, you need to contact a gas safe engineer to fit you a complete gas valve and carry out the safety checks required.
Jul 13, 2011 | Heating & Cooling
My potterton boiler ignites itself after turning it on then goes out
Assuming this is a combi boiler and you mean that the main gas burner comes on then off:-
How long after - 5-20 secs check overheat thermostat Check the wires to it are firmly in place i.e. making a connection. If Ok? then you can short this out by joining the wires together - do with boiler OFF at mains electricity
Longer - say 1-2 mins check secondary heat exchanger for blockage - usually furred up inside & only solution is replacement
Dec 22, 2009 | Water Heaters
Potterton Profile 60e doesn't start first time
could be fan speed or air pressure switch-is case seal sealing properly also check grommets under boiler for blowing.
YOU CAN ONLY WORK ON BOILER IF YOU ARE GAS SAFE REGISTERED.
Apr 04, 2009 | Water Heaters
Water heater pilot light
it also sounds as though the pilot injector could be blocked so when the boiler comes on it extinguishes the pilot & then when the burner goes off boiler shuts down, or also the pilot rate maynot be set right, so when the main burner kicks in it robs the pilot of the gas it requires.
It could be that, or there is lack of ventilation for the boiler, so you get flame lift off when the boiler fires?
Dec 14, 2008 | Water Heaters
Heating & Cooling Logo
175 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
