Question about GoVideo R6750 DVD Recorder
R6740 dvd recorder
The door will not open.
I tapped on the top of the machine and it opened
Posted on Oct 28, 2008
How do I unlock my dvd HDC 300 recorder?? The door does not open and says Locked
If you have the manual it should say something about a child lock
Oct 20, 2014 | Sony RDR-GX300 DVD Recorder
I have a govideo dvd recorder model #r6740 and
Straiten a paper clip, find small hole in front of cd face. Push paper clip in, It should release the tray.
Dec 29, 2009 | GoVideo R6740 DVD Recorder
Stopped recording/won't open door for disc at all
There's a slot on the bottom where you can insert a small slotted screwdriver and slide it to the left to get it open.
Apr 03, 2009 | iLO DVD Recorder DVDR05
Won't recognize Sony DVD+R DVD.
Maek sure the recorder does not require the DVD - Type disk
Dec 19, 2008 | GoVideo R6740 DVD Recorder
I cant get go video model #r6740 to be able to be connected to my cable box and still work help please
connect the yellow, white, and red cables from your cable box (output) to the (input 1) connector on the dvd recorder. Then connect the yellow, white, and red cables from your dvd recorder (output) to a (input) on your tv (make a note as to which input on the tv you use). then turn on your tv (set your tv by pressing input, line, or channel down from channel 2 until you see the input you connected your dvd recorder to). then power your dvd recorder on (you should see it on your tv screen), then change the input on your dvd recorder to input 1 (or which ever one you connected your cable box to). Then power on your cable box (now you should see your cable programming on your tv, passing through your dvd recorder). Now you should be all set to watch, and record what ever you want, (however most dvd recorders will not record copyrighted materal, their is a signal transmited ny the owner of the movie, or other content.)
May 11, 2008 | Televison & Video
DVD locked in and door is not opened
might have stuck inside...u got to open up the system onlly
Apr 01, 2008 | LG RH177 DVD Recorder/HDD Recorder
Cannot open door
belt is loose or gear is broke, if out of warranty you can try to force it or open the cover and see if you can push the door.
Dec 03, 2007 | GoVideo R6740 DVD Recorder
Disc Tray will not open
DVD door is opened by a small pulley-belt system. Disconnect the power cord and remove cover on R6740 (one screw on each side and 3 in back). Remove top cover on DVD drive (4 screws on top). Manually open door; you will see a small "O" ring sized rubber belt (they stretch and lose flexibility with time, which is why the door stops working). Remove and replace belt. I found a 11/16" X 1/16 belt at Lowe's in the plumbing dept @ 2 for $.59. Its not a perfect fit, but the door works now!
Nov 05, 2007 | GoVideo R6740 DVD Recorder
GoVideo R6750 DVD Recorder Logo
95 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
