Question about Car Audio & Video
Obcon 2000i protect light is on. ive checked all the cables and everything looks fine it was working for about an hour then the protect light came on and it doesnt work
  • Anonymous Jan 19, 2009
    i have the same problem. i checked all the wires and plugs and it doesnt even seem like the sub is getting any power whenever the protect light is on. I can't figure out how to get it to turn off.
techman
  • 3130 Answers
SOURCE: my amp quit working
ok I thought I anwered this one but first thing to try is disconnect all your speakers and see if the light goes out if it doesnt then your gonna need a schematic and a working know how on solid state amplifiers. first check al the outputs for the speakers for dc If theres dc on an output then that output device is shorted or leaky. Ive have open drivers as well as current control transistors leaky or shorted to that made the protection come on.. Good Luck
Posted on Apr 07, 2006
  • 58 Answers
SOURCE: Reverse lights not working.
Most likely. It sits on the front of the gearbox and has 2 wires going into it. Remove the plug and bridge the wires with a small piece of insulated wire. Turn ignition on. If lights are on change the switch
Cheers John
Posted on Dec 12, 2008
  • 11 Answers
SOURCE: Boss GT780 4 Channel 1000 watt mosfet amp protect light
fuses , ground wire , and battery fuse
Posted on Jun 18, 2009
  • 87 Answers
SOURCE: ive got a nemesis 100cc quad and the electric
might sound simple but have you checked the inline fuse from the starter relay?
Posted on Nov 18, 2009
Sutibun
  • 186 Answers
SOURCE: My Super Nintendo turns on but doesnt show
It is the SNES it has the same issues that the NES had simply turn off the machine remove and put back the cartridge and turn on. some times you will have to press the restart button a half a dozen times.
Posted on Jan 22, 2010
Testimonial: "Thats exactly what it was. Thank You very much. "
I have a kicker 10 comp d dvc 4 ohm 600 watt. How do I run a obcon 2000i 2 channel amp to it
You can't. Total mismatch of power and impedance.
You need a mono amp that can push the RMS watts of the sub @ 2 ohm (sub wired parallel).
More info here - http://sparky3489.webs.com/
Jan 22, 2015 | Kicker Car Audio & Video
ROUTER WONT CONNECT NO MORE IT SAYS THERE IS NOW ETERNET CABLE
Have you tried updating the driver? search..type in device manager...............right click on the network adapter and choose update
Sep 05, 2017 | Belkin F5D72344 Wireless G Router 54Mbps...
How do i keep my amp from getting hot?
Ensure you have ample air flow over the unit. If there's no airflow and your pulling a lot of juice, it has to disipate that heat through the heat sinks. The only way that can happen is to have adequate airflow. Remember nothing kills your boards like heat.
Oct 01, 2010 | Dual Obcon OB 2000i Car Amp
Headlights wont work, just suddenly stopped!
recheck them fuses sometimes they dont look blown but they are if not there must be a loose connection somewhere i know you have checked but retry
Jul 28, 2010 | 2005 Suzuki SV 650 S
Everthing on the amp is hooked up right but the two wires from the amp to the cd player and its in protect mode how do i get it to play
The protect light comes on sometimes when the ohms of the speakers are not ran right. if I knew what speakers you had hooked up i could help a little better.
Jan 27, 2010 | Dual Obcon OB 2000i Car Amp
Wat is the wattage
Hello
Just click on the link below and you will be directed to a page which states the key fetures and reviews. It states the wattage of the amp clearly. Hope this can be of help.
http://www2.shopping.com/xPO-Obcon-OBCON-OB-2000i-1000-watt-2-channel-amplifier
Kind regards
Andrea
Dec 16, 2009 | Dual Obcon OB 2000i Car Amp
My kenwood kvt 514 is in protect mode
It sounds like your amp is not grounded properly and is tryin to use your radio as a ground through the RCA's or there is a bad channel (dead short) in the amp.
Jun 02, 2009 | Car Audio & Video
Lanzar Vibe 1200D protection light
You will need to show it to a service technician as it seems the output section has blown so it remains in protect mode. One reason (could be) that the input to the amp was high and may have been clipping for some time before the amp decided it could take it no more
Jan 14, 2008 | Lanzar Vibe 1200D Car Audio Amplifier
Falty Amplifier?
It sounds like the output transistors have shorted. This is VERY common. If you want to try to troubleshoot the problem, I'd need to see photos of the inside of the amp. You'll need a multimeter to check the transistors.
Before opening the amp, remove it from the power source.
Since the resolution is severely limited here, send the photos to me directly (babin_perry@yahoo.com). If you're going to send multiple photos, please zip them and send one file.
Dec 21, 2007 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
My amp quit working
Apr 07, 2006 | AudioBahn A6004T Car Audio Amplifier
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
