Question about Singer 1120 Mechanical Sewing Machine
How to clean and take apart a singer sewing machine
How to take apart a singer sewing machine to clean it
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 43 Answers
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
Posted on May 06, 2009
  • 980 Answers
SOURCE: repair singer 502 sewing machine
You can get the fears quite easily and fit them yourself and if you email me I can attach full instructions.
drivewithken@blueyonder.co.uk
Posted on Sep 19, 2009
SOURCE: Looking for a free download of Singer Sewing Machine 6235
if you still haven't found one, reply to this thread. I have one as a PDF that I just bought for $5 that I'd be willing to share (this goes for anyone who finds this post, too)
Posted on Feb 26, 2010
Where is the timing belt on a Singer 3820 located
The timing belt is inside the bottom of the machine.
Dec 07, 2012 | Singer 3820 Mechanical Sewing Machine
I have had a singer prelude 8280 for a year now with no problems. now all the sudden the thread is catching in the bobbin casing. The thread on top looks normal, but when you turn over the fabric...
change the needle
clean under the needle plate where the feed dogs are for lint
make sure the thread has not come off the thread take up lever
rethread the machine
Nov 20, 2010 | Singer 8280 Mechanical Sewing Machine
My singer 4228 needle keeps hitting the round metal shank that turns in the machine
Did you have it apart for cleaning and maybe it is not seated right? I asked a repairman, and he said most of the time it is that the needle is not inserted right, or above problem Other than that your timing may be messed up and you need a professional to look at it.
Oct 05, 2010 | Singer Inspiration 4228 Mechanical Sewing...
I took the bobbin area of my Singer Stylist Sewing Machine 533 apart to clean it, had an interrupting phone call and went back to the machine and couldn't remember how the parts go back. Please help me if...
If you do not have your manual, you can download one for $10 at www.sewingmanuals.com and it is safe because they use paypal. Normally manuals have all the directions for cleaning and diagrams of how things should go. I had to resort to getting one for an old machine and I felt it was worth it. Singer charges $15 for a hard copy of your manual. Good luck, wish I could be more help.
Oct 05, 2010 | Singer Sewing Machines
I bought a 5050 model on ebay and the handwheel is
Unless you want to deal with the little screws to take it apart, you may take it to an authorized singer service dealer. Look in your local yellow pages under sewing machines.
Apr 08, 2010 | Singer 5050 Mechanical Sewing Machine
The upper thread spool breaks all the time when I start sewing after four stitches.
Step 1
read the manual completely before u start.
Step 2
Use the handwheel to make the needle rise and fall. Repeat this process with the foot pedal, treadle or knee press. Wind a bobbin and thread your sewing machine. Sew several test seams to assess the problems with your machine. The most common problem is a tight or sticking handwheel and machine movement. Step 3 Unplug your Singer sewing machine and dismantle it. Remove visible screws and take the machine apart as far as you are able. If the motor is mounted on the back of the machine, remove it. Repairing a Singer sewing machine, regardless of the problem, will start by taking apart the machine, cleaning it and oiling it.
Step 4 Use tweezers to remove any loose threads from the bobbin area and threading assemblies. Compressed air may also be used in small amounts; however, you should be wary of pushing lint further into the machine.
Step 5 Use a rag with a lubricant like WD-40 or Liquid Wrench to clean all accessible gears and moving parts. Wipe the lubricant away thoroughly and apply a drop of sewing machine oil on moving parts of the machine. Examine your Singer sewing machine carefully for broken gears or pieces. Check the belt, if visible, for signs of wear.
Step 6 Use an emery cloth to smooth away any burrs or rough spots on the bobbin assembly or feed plate. Often a small burr can cause significant problems with thread breakage.
Step 7 Reassemble you Singer sewing machine, assuming you cannot see any visible broken parts or damage. Try sewing with your machine again. If you have noted problems with the motor or gears, your local Singer repair shop may be able to order parts for you if you want to handle a more involved sewing machine repair on your own.
Step 8
Use a mild solution of water and a basic soap, such as Dr. Bronner's or Ivory dish liquid, and a clean, well-wrung rag to wipe down the outside surfaces of your Singer sewing machine. Dry the sewing machine well. Very old machines may benefit from an application of sewing machine oil to the exterior of the metal sewing machine casing. Rub in well and wipe away the excess.
now try sewing... hope ur problem could have been recovered.
Jan 11, 2010 | Janome Memory Craft 9000 Computerized...
Bobbin won't p/u thread Singer 478
i have no idea how to thread this machine ?
Jul 05, 2008 | Singer 132QRFB Mechanical Sewing Machine
Singer 1120 Mechanical Sewing Machine Logo
35 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
