Question about Dremel & Stylus Lithium Ion Cordless Rotary Tool
Dremel 1100 for in a few seconds - Dremel & Stylus Lithium Ion Cordless Rotary Tool
Jo83286
Thank you very much for your instruction. I repaired my dremel charger.
Posted on Jun 17, 2015
  • Tugsuu
    Tugsuu Jun 17, 2015
    jo83286
    New Friend:
  • 4 Answers
Change the capacitor 220uF 25V and it will charge properly again (at least that is the result I got and several others here at FixYa).
Easy to do and cheap (component around 0,2 Euros) work about 2 min,.
Posted on Apr 02, 2013
How can I locate capcisator for Dremel Stylus Lithium-ion model 1100 ? It has got charging problem.The Stylus is a cordless tool.
Do you mean a capacitor? Is it the charger or is it the battery? The capacitor are plain types can be found at any electronic parts store. I think the main one is 220uf. Be sure an check each for problems.
Jan 18, 2015 | Dremel Tools & Hardware - Others
Why does Flexshaft get hot after a couple seconds
Perhaps you are bending the shaft too much, or the original lube in the flex shaft has been compromised. Take it back to the dealer, for an exchange.
Jul 12, 2014 | Dremel Variable - Speed Multipro Rotary...
Dremel stylus 1100 (No Charger)
First you need to get an equivalent charger and some type of male/female or contact harness. This will have to have at least three pins as that is what is already on the Dremel. Now the difficult decision, do you want to open up the Dremel if it's still under warranty? If you don't mind opening it then my solution will work. Open up the Dremel and look at the inside of the contacts. As this is a DC charger it can only have positive and negative terminals. You say there are three contacts, so there will either be two positive and one negative or two negative and one positive. Most likely there will be a bridge wire between the two terminals with the same polarity. Strip a little of the insulation from the terminal wires and solder new leads to your contact harness. Noting the polarity of each pin/contact on the new harness wire the other part of the contact harness to the charger. You will most likely have to make a small hole in the Dremel's outer cover to allow the wires to pass through. As you own a Dremel I'm sure you are capable of attempting this easy bit of DIY. There is only one problem, If the third contact plate is a return signal to the charging base it might be to inform the charger when the battery is full. In this case the terminals inside the Dremel will not be bridged and I suggest you buy a new or secondhand charger. Hope this helps
Nov 15, 2013 | Dremel Cordless Stylus, 7.2V, 5, 000-25,...
Dremel Stylus 1100 runs for about 15 seconds then shuts off. It restarts with power button then repeats the process. How can I repair it?
Open case, should have thermal breaker near motor which supplies power to motor, check continuity through it.Thermal over load maybe.
May 19, 2013 | Computers & Internet
I need help attaching the new bit to the dremel model 1100
Hi leigh abear...
I will send you to the dremel website where you can watch a video on the dremel model 1100 and it will explain how to use it and change bits,cutters,ect.
Do change your bit without going to the website push down on the large button on top to lock the tool, and then you wil loosen the bit holder bu turning it anticlockwise to loosen the grip on the tool you have in the bit holder.
Please take time to rate me
http://www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=1100
Sep 09, 2011 | Dremel Garden
Dremel 395 Rotary tool won't turn on or won't stay on but a second or two
Electrically speaking there are a few items to check.
1) The easiest is to remove the two brush holders screws on each side by the power cord. If one of the screws are loose, or the bushes are worn you will get intermittent or no operation.
2) Second use a volt ohm meter to make sure you have voltage on the two brush connectors inside the brush holders when power is on. If you do then open the unit a check continuity on the motor armature to see if it is open, which will cost $13.37. If you do not have voltage, inspect the power cord and switch.
Some parts can be purchased on the below link.
http://www.ereplacementparts.com/dremel-395-f0130395ca-corded-multitool-parts-c-15440_15456_15474.html
Or contact a dremel service center from the link below.
http://www.dremel.com/en-us/customerservice/ServiceAndRepair/Pages/default.aspx
Apr 27, 2011 | Dremel Variable - Speed Multipro Rotary...
Dremel Stylus model 1100
Change the capacitor 220uF and it will most certainly work again. I got the idea from FixYa and it solved my problem!
Easy to change just 2 soldering points and a component costing around 0,2 Euros. If you do not know how to operate a soldering tool ask someone for a quick assistance. The switch takes around 2 min (1,5 min to open the charger and 0,5 min to change the component!).
/Johan
May 05, 2010 | Dremel & Stylus Lithium Ion Cordless...
New Dremel 300 stopped working. What's wrong?
Something amazing just happened! On my monitor screen, window popped up that said, "ASK A QUESTION - LET OUR EXPERTS SOLVE YOUR PROBLEM FOR FREE".
I couldn't resist getting expert advice for free, so I clicked on the window. I was immediately taken to a magical world where I can pay for expert advice. I opted not to pay for expert advice. The next day, I was asked if the help I received was helpful. So here I am posting this response. I haven't received any expert advice yet, but when I do....!
Jun 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Dremel & Stylus Lithium Ion Cordless Rotary Tool  Logo
490 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
