How do you charge
HOW DO YOU PUT IT ON CHARGE?!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Audio Player... Master
  • 102,366 Answers
Most MP3 players charge automatically when you connect it to a powered USB port using the supplied cable. There's no switch or button to push, the charging happens automatically.
If you need more specific instructions, please feel free to reply to this post and specify the make and model of your player.
Posted on Feb 18, 2012
Razor electric scooter e 300 battery charges but won't run
first check to ensure the batter has held the charge you put into it. Just plugging the charger in does not mean the battery is holding the charge. If the battery is bad, it will drain as fast as you put it in. if the batter holds a charge, should be able to disconnect the charger and battery will show charge. if so, you have a bad connection or motor.
Jun 29, 2013 | Motorcycles
WHY IS TI THAT THE BATTERY KEEPS LOOSING ITS CHARGE AND IT DOES NOT HOLD CHARGE?
put a volt meter on the battery,,,,it should read 12.6 before starting..and 14.25,,when running.....and 13.75 when you shut it down,,,,,if not its not charging...you need a good battery to turn on the regulator/alternator/stator/rotor to charge the battery,if its not 12.6 your dead in the water
May 05, 2013 | 2007 Vento Phantom R4i
It doesnt turn on and charge
If you charge off USB and the device won't turn on you could try charging it with a wall charge as some devices need to be on to charge from USB .
Jan 03, 2012 | Emerson Audio Players & Recorders
My battery for canon camera 550d flashes orange when charging, its been 4 hours now and it hasnt turned green yet.. I am charging it first time.. is this normal
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Apr 19, 2011 | Canon Cameras
I turned my LG GD510 off earlier then put it on the charge as it had two bars of charge left but when i went to turn it on it wouldn't even if i put it on charge and ive tried everything
It happens sometimes. The bars that are shown are false. So you should check whether you really have the charge or not . just switch on the music player for two minutes and it will show you the original charge remaining on the icon.
Feb 26, 2011 | LG GD510 Cell Phone
My Scooter (Fisher & Paykel - Columbus) Will not charge
Hi. These machines will not charge themselves if the batteries are too flat. The charging system is run by the micro processor IC in the scooter. If the battery voltage is too low the the IC will not have enough voltage to operate.
Remove the batteries from the machine and charge in parallel on a 12 volt charger. Once they are charged, put them back in the machine, and try the scooter on charge again.
Good luck. Neil.
May 15, 2010 | Health & Beauty
Put camera in cradle to charge. red light comes on for about 5 secs, then goes out. can't get camera to take a charge...
try connecting a 9volt battery with a couple of jumper wires to the correct terminals on the battery for about 30 seconds then put it on charge(positve to positive negative to negative) if the battery is to low the charger won't pick it up and start the charging cycle by connecting the 9volt to it t will put a small charge to it to start the charger
Oct 15, 2009 | Sanyo Xacti VCP-HD2 Camcorder
How long and how often should I charge my Palm Z22? How long does it hold a charge when fully charged?
It will usually only take a couple of hours to fully charge your Palm. As to how long it will hold that charge will depend on how much you use it. If you just put it in your pocket and not use it it will hold that charge for a week or more. If you use it all the time you will want to charge it whenever the battery gets low. I usually put my charge on the charger at night and then I am good to go for all day long and I use mine quite a bit. Hope this helps.
Sep 18, 2009 | Palm Z22 Handheld
New phone put to charge but charge light goes on
battery may be faulty or the software needs to be reload
Jul 06, 2009 | Motorola Mobility RAZR V3
37 people viewed this question
 Grubhead
Grubhead
