Question about Cuisinart DGB-600 Coffee Maker
Coffee maker won't start and just beeps when plugged in
When I plug the coffee maker in it just beeps at me and won't turn on. I can press the 1-4 cups button and the grind off button and the lights come on but it won't actually start brewing or do anything for that matter. What should I do? Thank you, Aimee Roth
  • 1 more comment
  • Anonymous Mar 02, 2008
    I have the same problem on the 500. The coffee maker is only a few months old.
  • Anonymous Apr 06, 2008
    I have same problem my DCG-600 coffeemaker is just beeping and will not turn on please help the noise is killing me
  • Anonymous Mar 31, 2014
    when I plug coffee maker in outlet and select on button the coffee maker just beeps - the motor doesn't even go on
The door on the top is not closed properly. When you open the top door(cover),you will see a button that is located on the top of the grinder cover. that is a switch that tells the coffee maker that the door is closed and can safely make coffee..please check that all parts are in place and top door(cover) is closed comepletly. good luck.
Posted on Jun 26, 2007
SOURCE:
How do you set the minutes on the clock?
There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
Source : Krupsusa.com
Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
My em 200 cuisinart espresso maker stops brewing and beeps
My em 200 Cuisinart express
maker start and stop and beeps what I do
Jan 14, 2013 | Cuisinart EM-200 Espresso Machine
Lite is on will not brew there is water and coffee and it doesnt brew
You can try this.
1. Plug the coffee maker into the wall power outlet. Turn the switch on. The light will glow. Then press the on/off switch TWICE. The coffee maker will start.
2. If the machine doesn
Aug 02, 2011 | DeLonghi DCM485 Coffee Maker
While attempting to clean our DGB-500 Coffee maker, my wife touched a button, and now it continues to beep and will not start. Can you give us a suggestion as to how to get it to start.
I think that touching any button should not get any problem to the Coffee maker. But, I would try to unplug it from the wall outlet and let it unplugged for at least 10 min, in order to reset the Microcontroller inside it. Then try again to put it working. If nothing changed, try living it unplugged for more time. Or try pressing buttons and hold them some seconds while plugged on AC.
Dec 10, 2010 | Cuisinart DGB-500 Coffee Maker
Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
May 15, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
Beeps constantly
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
These instructions are to a DGB600 but i think it is the same to your model.
May 24, 2008 | Cuisinart DGB-500 Coffee Maker
Cannot turn off alarm.
Hope this will help you.
/Mirran
May 09, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Will not turn on
i had the same problem. i had left a part out, the clear top to the beans. Once I put it in, it worked. i think this is a safety featr=ure
Dec 25, 2007 | Cuisinart DGB-600 Coffee Maker
Turning off the beeper
The manual is not too clear on this function. Turn the coffee side on, press the middle button on the coffee side for > 2 seconds and then use S1 and S2 button to select a mode that does not show the bell.
Jul 11, 2007 | Krups XP2070 10 cup Coffee Maker/15 bar...
Cuisinart DGB-600 Coffee Maker Logo
580 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
