Question about Gateway FPD2275W LCD Monitor
Sfer a few miutes montor goes blank
How do I FEEP MY MONTOR ALWAYS ON
  • 47 Answers
Well happy to help . u can always keep ur display on by clicking right click then going to properties.a window will open.u go to the screen saver option and then click the power button another window will open there u will find a power schemes there u click the option below it and select the always on option and u r done. pleasure helping u.
Posted on Oct 26, 2008
When i turn on computer the monitor shows the windows screen or sign in page then go es blank then does the same thing if you power off manual then restart its like it goes to sleep but theprogram is...
this sounds like the screen may be trying to display a resolution higher than the screen can support. Try booting up in safe mode and seeing if you can see your desktop. Also is this the only monitor connected to your PC or is this a dual screen setup? If it is dual screen you may not have your second montor turned on.
Dec 03, 2010 | HP 2159M Monitor
2007 C90 after rideing it for about 45 miutes the Battery goes de
Have your Regulator/rectifier checked , and have your ststor checked also . Both are not hard to fix , regulator about 15 mins and ststor about 45 mins .
Mar 22, 2010 | 2005 Suzuki Boulevard C90
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Screen go black or blank a few seconds after starting up. Connected external montor and that works fine
Check with the installation of graphics drivers and other wise this might be a display panel cable issue.
Aug 13, 2009 | Gateway Computers & Internet
Comp not reading montor
It sounds like the on board video has failed. I would try installing a video card on the motherboard. Then in the bios at start up, disable the on board video, so it will use the video card instead.
I hope this helps and thanks for using FixYa,
Eric
Jan 25, 2009 | eMachines T6534 PC Desktop
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Acer Monitor will not function
Monitor is getting hot and cutting off. Try on another computer. Try another video card. If it does the same thing then it is BAD
May 24, 2008 | Gateway FPD2275W LCD Monitor
Screen montor goes blank
If the standard power settings are grayed out than most likely the laptop shipped with an alternate program that handles power settings. Look in the start menu thoroughly, it will be in there somewhere.
Sep 30, 2007 | HP Pavilion dv8000z Notebook
PC starts fine, then the montor blinks and no display. light stays green
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps. Try this as it is a common problem I find a lot. Good Luck.
May 24, 2007 | ViewSonic VX900 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
