Question about Whirlpool Gold® GC5SHEXNQ
What does the condensor coil look like - Whirlpool Gold® GC5SHEXNQ
  • Whirlpool Master
  • 4,655 Answers
Your model has the condenser below the refrigerator and the condenser is the item number 3 in this photo=> GC5SHEXNQ00_Unit_Parts It is the warm side coil that you feel warm air coming from below refrigerator. The evaporator coil is inside the freezer on your model. Thanks Sea Breeze
Posted on Feb 18, 2012
My Window unit cools real well in the morning. The air flow from the ac is 50 degrees, then by noon the temperature is 80 degrees and then it won't cool again. I am trying to cool an 8 x 35 ft....
When was the last time you cleaned the evaportor coil and condensor coil???? When its cool outside the condensor if its plugged with dirty can mantain the right condensor Head Pressure by useing the cool outside air when it has to run with 80 to 100 degree air it can't get the head pressure with in range to cool the freon. I would clean the condensor coil.......
Jun 19, 2011 | Friedrich ZStar ZQ10A Air Conditioner
Tip
Easy way to check if ur condensor coil is clean
while in operation, with condensor fan running, hold a piece of thick paper up to condensor coil, let go of paper, ir it stays stuck to the coil, the fan is pulling air thru, cooling the coil temp. this is good. if the paper dont stay in place ur condensor coil is dirty and needs to be cleaned
on May 22, 2010 | Heating & Cooling
Blows hot air after 5 min. of startup
Check condensor coil for uniform heat all over the coils
If there are "hot spots" Then the condensor may be restricted inside
Check compressor heat. If its too hot to lay your hand on it then
You probably have a restricted condensor which shuts off the compressor with high head pressure
If the unit is old you may want to consider a replacement.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 23, 2010 | Soleus MAC-7500 Air Conditioner
Inside strip of fridge is very hot. cleaned out behind fridge and the coils, etc. fan is barely moving/not moving. any suggestions???
Replace the fan. The strip has a freon line running behind it, and when it is hot, this tells us that you have a dirty condensor, bad condensor fan motor, bad evaporator fan motor, defrost problem, or a freon system problem. When you say your fan is barely moving, I am assuming this is your condensor fan motor, which sucks air through the hot freon lines in the condensor coils, and cools the freon off. If it is barely moving, it can't cool the freon. In some brands a slow moving condensor fan can be caused by a bad main control board. Good Luck, Appliance Specialists
Jan 28, 2010 | Refrigerators
Runs but won't get cold
The first step would be to clean the condensor coils to remove the dirt accumulation which decreases their efficiency. Also, check to make sure the condensor fan is operating properly. This pulls room air over the condensor coils and cools the refrigerant.
Oct 09, 2009 | Kenmore Freezers
Where do the 2 wires that go's to the points go
The condensor and negative coil wire both attach to the contact points. When the points are closed the ignition coil charges ( sota speak) and when the points open, the coil discharges a spark to the spark plug. The condensor is an electrical "shock absorber", it smooths out electrical spikes.
Good luck, make sure the point gap is correct.
Regards,
Jul 21, 2009 | Garden
D50c
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Aug 10, 2007 | Friedrich D50C Dehumidifier
Whirlpool Gold® GC5SHEXNQ Logo
123 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
