Question about Nikon COOLPIX Cameras
My s3100 doesn't charge using either cable provided
When charger plugged in, nothing happens.
  • 734 Answers
Bad battery? or battery contacts dirty?
Posted on Feb 18, 2012
3 Suggested Answers
  • 214 Answers
SOURCE: I Have A Nikon Coolpix s210 Camera And Everytime I
HiIn order to check quick, you might need extra battery. In your neighbor some who has multimeter you get help from them. Or your local repair shop could help you easily.
Posted on Jun 02, 2011
  • 102366 Answers
SOURCE: When I connect my Nikon
Receiving no response to my query in over two months, I assume my suggestion to use a card reader solved the problem.
Posted on Aug 16, 2011
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
My Nokia E73 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 15, 2012 | Nokia E73 Mode Cell Phone
Hi Mine is a iPhone 3GS 16gb it will not charge nor turn on when I hold down the on off button nothing happens but when I plug in the charger and hold the on off button it shows the charging sign which...
First Option:
Second Option:
Aug 31, 2012 | Computers & Internet
Battery will not charge
There are only three likely solutions.
1. The charge port on your phone is broken (Most likely)
2. The battery has reached a thermal cutoff and will no longer accept a charge.
3. The charger cable is bad.
If you can try another battery or put that battery into another phone you can isolate that problem. If you can charge something else with your charger then your charger workers.
If that still doesn't work then plug the charger into your phone and lightly press on the charger. If your phone springs to life it means the charge port is likely suffering from a poor connection. If this is the case then sadly there is nothing you can do unless you're very good at soldering.
Jul 24, 2012 | Cell Phones
I was on the phone with my BB Torch, then the battery ran out, i got back the next morning, tried to put it on charge, nothing happen, no red light, no indicator , nothing, tried the charge for few ghours...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. If the red light doesn't come on, connect the charger and put the battery inside. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 09, 2011 | RIM BlackBerry Torch Cell Phone
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
Cameras Logo
188 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
