Question about Shuttle sn Computers & Internet
Optiplex 320 wont boot. Amber power light and fans running
Motherboard light is on, doesn't complete power on cycle. Monitor flashes the dell screen and then only fans run. Power light is amber
  • 407 Answers
Power off 1st..then open ur cpu ..check ur ram ...and clean it....or mother board is not work replace near hardware shop....or check ur bios bettery or change it
Posted on Feb 19, 2012
5 Suggested Answers
jelacio
  • 10 Answers
SOURCE: I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Posted on Aug 20, 2008
kornho
  • 781 Answers
SOURCE: motherboard change
jethro..
http://support.dell.com/support/edocs/systems/dimC521/en/SM_EN/tshoot.htm#wp1064555
check on system lights... what are the diagnostic lights telling you??
if the 4 lights are off you may have a problem with the led itself or the powersupply is just messing with your head.
Posted on Dec 02, 2008
ajx13
  • 110 Answers
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Posted on Aug 11, 2009
nitin_s_s
  • 29 Answers
SOURCE: OPTIPLEX 960 error codes 1 and 3 at startup
Blinking amber ... seems like an isuue with the power supply .. check if you see the power supply fan spinning at the back of the system tower... If its spinning then you could try reseating the memory modules inside the system tower . Opem the tower and then disconnect the green colour ruler shapped modules which has a latch on either sides. then try turning in the system ... check if turns on properly.
Hope its informative.
Posted on Apr 02, 2010
Testimonial: "Thank you - computer works with another power supply. You got it, Master!"
Flashing amber light
Hi, on most Dells a flashing amber light on the power button indicates a problem with the PSU or a short on the main power rail, if this is the case you should have 2 flashing lights as well, 1 & 3.
May 05, 2014 | Dell OptiPlex 3010 MT Desktop Computer
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Solid amber light ON Dell Inspiron 530 desktop.The Fans start and stop immediately.The mother board has the power ON Amber light.
The Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Mar 04, 2010 | Dell Inspiron 530 Desktop Computer
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
DELL XPS 700 AMBER LIGHT
you don't tell us from where coming the amber light from the cpu or from the monitor?
May 29, 2009 | Dell XPS 700 PC Desktop
Solid amber power light
Your Monitor is not connected properly
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Connecting Your Monitor
1. Turn off your computer and unplug the power cord.
2. Connect the white connector end of the DVI cable attached on the monitor to the connectors on the computer.
3. Connect the USB cable that was included with your monitor to the computer and the upstream USB connector on the monitor. Once this cable is connected to the computer and the monitor, you can use the USB downstream on the monitor.
4. Connect any USB devices.
5. Connect the power cord.
6. Turn on your monitor and computer. If you do not see an image, see Troubleshooting Your Monitor.
NOTE: The Monitor will display full screen in White, Black, Red, Green and Blue color rolling pattern on screen if the DVI cable is not connected. This self test pattern will be displayed continually when Monitor detects that DVI cable from Monitor to PC is not connected.
* Check connection integrity at both ends of the video cable.
* Ensure the monitor and computer are plugged in to a working electrical outlet.
* Ensure power button is depressed fully.
Aug 14, 2008 | Computers & Internet
DELL COMPUTER WOUN'T START
1. Ensure that the power supply is working
2. If yes then make sure all connections are properly connected
3. If No,you will need to buy a new one
Jul 12, 2008 | Dell Computers & Internet
Amber Light and fan running
1st thing, disconnect everything but keyboard mouse and monitor, see if anything changes.
If the issue persists, ensure that all power and card connections for the motherboard are tight and secure. If you've added RAM or other parts, remove them. Reseat the RAM in the motherboard that came from Dell.
If none of those ideas have any effect on the issue, replace the motherboard.
Jul 01, 2008 | Dell Dimension C521 PC Desktop
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
550 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
