Question about Honeywell Heating & Cooling
I have a Honywell, Model RLV3120, and it gets very hot to the touch while it is on. Is this normal? The other thermostats in my house do not get hot.
2 Suggested Answers
  • 587 Answers
SOURCE: i have a honywell programable thermostat, that,
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Feb 23, 2010
Testimonial: "thank you very much for the info, i'm calling my electrician today, thanks again. john st louis"
My whirlpool electric dryer model#le5700xsno...got
THE THERMAL FUSE LOCATED ON THE BLOWER HOUSING
Sep 19, 2014 | Dryers
Where is the thermostat and how do i test it
follow top radiator hose it will take you to the thermostat housing.to check thermostat when engine is hot both radiator hoses should be hot to touch if the top radiator hose going to thermostat housing is cool not hot when engine is hot. the thermostat stuck closed causing engine to over heat need to replace thermostat and radiator pressure cap.when replacing thermostat make sure to pay attention to position of thermostat so you can install new thermostat in the same position.
Dec 10, 2011 | 1994 Volvo 940
Dryer runs properly but gets very hot on the back, almost too hot to touch. I replaced the hi limit thermostat but no change.
If you dryergets too hot to touch. I am sorry to sayit is your heating elements. One of themis touching the housing and making the a connections to the housing. Usually this repair is not that expensive toget repair.
May 11, 2011 | Dryers
Cant take off cover to replace battery from my honywell thermostat
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Nov 26, 2010 | Honeywell Programmable Thermostat Heater
Thermostat sticking closed, engine overheating
Follow the upper radiator hose to the fitting it is attached to. It should have a dome shape to it. remove two bolts on either side and pull out thermostat housing. the thermostat is right there. Replace thermostat and gasket. Be sure to point large copper colored end with the bimetal spring towards the engine when installing new one. Replace housing cover and tighten down bolts. Start and run engine. at some point, the thermostat will open and the upper hose will begin to get hot to the touch. after this hot water is cycled into the radiator, one electric fan should kick on for about 30 seconds and shut off. This just cooled off the next incoming charge of water to go into your engine. To test your old thermostat place into a pan of nearly boiling water. you should see it open up if it works. If not, then you did the right thing and should run normal temps.
Nov 14, 2010 | 2003 Dodge Intrepid
I have a honywell programable thermostat, that, once a week or so, " unprogammes itself and shows a code "olo eo", the problem started about the same time an electrician came to our house to do some work,...
Go to honeywell.com
Feb 22, 2010 | Honeywell Programmable Thermostat Heater
Estate dryer electric model ytedl856aw1
hi thanks for the question no you don't need thermostats your heater is probably touching the heater housing so you would need a new heater thanks the appliance doc
Apr 01, 2008 | Estate TEDS740JQ Electric Dryer
Dryer too hot
You will want to make sure the lint screen and vent are free and clear.
If the dryer is blowing out the vent outside the house as it should, then you have a thermostat problem.
If the operating thermostat does not open properly then the element will cycle by the hi-limit thermostat which will cause the dryer to heat more than normal.
Nov 24, 2007 | GE DWSR405EBWW Electric Dryer
Dryer does not get hot
pleas4e help my dryer is working but it won't get hot it just blows cold air please help me fix this problem
Jul 20, 2007 | LG DLE0332 Gas Dryer
Heating & Cooling Logo
73 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
