Question about Drills
C7 36 volt charger not working keeps blowing internal fuse
Fuse in charger keeps blowing i think transformer is gone where can they be got or new circuit board. Rang hilti they dont sell circuit boards
    Genius:
  • 1,212 Answers
If the fuse is blowing before the battery is installed to charge, the problem lies on the circuit board. Since it is most likely a switch mode supply, you might try replacing the electrolytic capacitors first. Then check what should be a MOSFET, although some may have a regular bipolar transistor as well.
If the charger blows the fuse when the battery is installed for charging, the battery has some shorted cells that overloading the charger, or the contacts are distorted and being shorted by the battery
Posted on Feb 18, 2012
3 Suggested Answers
  • 61 Answers
SOURCE: hilti c7/36 I am looking for a electronic diagram
if the light on the charger are functioning ok. the problem is most probly the batterys. they dont last forever, replace the batteries and you should be ok.
Posted on Aug 12, 2010
rowdy45176
  • 2176 Answers
SOURCE: do you know where i can find electronic diagram of
contact their tech support direct at 1-800-879-8000 for assistance
Posted on Dec 01, 2010
Why does it blow controller fuse when key is turned on?
Electrical: Circuits, Relays - SwedishBricks
www.swedishbricks.net/700900FAQ/Electrical-CircuitsRelays1.html
fuse keeps blowing Drills & Drill/Drivers Questions ... - Fixyawww.fixya.com > Forum > Tags > fuse keeps blowingDrills & Drill/Drivers fuse keeps blowing questions and answers. Ask your fusekeeps blowing drill and drill/driver questions. Get free help, advice & support for ...Ryobi Multi-Volt Battery Charger Fuse - Questions - Fixyawww.fixya.com > ... > Ryobi > Ryobi Multi-Volt Battery Charger1423701) and have blown the internal fuse. The label on the charger indicates the input is 120V AC. Question about Drills & Drill/Drivers. 1 Answer ...Remember that fuses can fail without showing signs of an obvious ... remember that suspect turn signal flashers, fuses, bulbs and relays can be ... will be predictable, such as a bad current or ground connection, blown fuse and the like. .... The relay then sends power to all the lock motors (all doors except driver's door).Missing: drills
[PDF]Electrical Safety - Occupational Safety and Health ...
https://www.osha.gov/.../4...
Occupational Safety and Health AdministrationShe has an older drill with a steel housing and a 3-prong plug. ... current. This willgenerally allow enough current to flow so that a fuse will blow or a circuit breaker is tripped, thus turning off the electricity in that circuit. ..... There are three major ways tocontrol power line hazards: 1. ... Install warning signs at driver's eye level.Missing: drills ‎key
Jan 07, 2016 | Drills
Thermostat fuse keeps blowing
The fuse protects the transformer from being damaged due to too much amperage, this is typically due to the circuit having a short or a device in that circuit being shorted.
See below the transformer's relationship to the thermostat.
The RED wire is the "hot leg" of the 24 volt power provided by the transformer to the thermostats R or RED terminal as pictured below.
The 24 volt hot leg enters the thermostat on R or RED.
The various other terminals White = heat, Yellow = cool ,
Green = fan and Common is the side of the 24 volt power source that every 24 volt circuit terminates or return to complete the circuit.
Thus the common name designated, note hoe everything returns to Common.
Well if we jumped Red directly to Common that is a short and will blow the fuse as you observe.
See the 2 diagrams in red describing a notrmal circuit then a short circuit.
Mar 03, 2015 | Heating & Cooling
The charger blows the 3.15a/250v slow blow fuse the second I plug it in... what can I do to get the charger working again?
check that you have the red lead of the charger on the positive terminal of the battery and the black lead on the negative terminal of the battery. Next check the voltage to be charged is selected correctly 6 volt or 12 volt. next check the rating of the fuse used as 3.15 amp may be too low for the charger. I would not go greater than 5 amp at best. Lastly have the charger checked by an accredited electrician for internal shorts.
Jan 17, 2015 | Cars & Trucks
Coleman furnace dgaa077bdta
The control fuses keep blowing tells me one or more of the control that operate the control on 24 volts is malfuctioning. Most controls operate at about 5 watts and on a clamp on amp meter normally pull about 0.2 amp (p = current x voltage, 5 watts = 0.2 amps x 25 volts) I install 75 watt 24 volt transformer with a resettable overload to save on fuses. I reset the transformer and quickly go to the controls and determine the amp draw. When I find the one >0.2 amps I found the problem. The things to check is the emergency heat sequencer, fan control sequencer, reversing valve for heat pumps, main contactor on the condensing unit and any other 24 volt control loads. I have had to replace the themostat wire because the increase current for the thermostat wire can cause the entire length of wire to form a long heater and cause insulation degradationa and cause the thermostat wire to short out and blow the fuses.
Hope this helps
Aug 30, 2014 | Coleman Mobile Modular Home Gas Furnace...
I have an elesis RA 500 it blows the slow blow fuse when i plug it in .any ideas what is wrong?
hi there,
it sounds like the internal transformer has gone.
It's not user replaceable and will require you to take to an electronics store to be repaired.
SAME THING RECENTLY HAPPEN WITH ONE OF MY BITS OF KIT ...... for heavens sake don't just keep changing the fuse time and time again.
Jan 07, 2011 | Alesis RA300 Amplifier
Powered Subwoofer repair--- Transformer issues?
Well yes transformers do fail and the transformer does say it has an internal fuse fitted which might have failed. The fuse on the board blowing is an indication of overload. The fact it didn't blow again shows that it is not getting any power or the fault has gone (doubtfull).
I doubt the transformer is a step up. But follow the circuit on the pc board till you come to electroytic capicator. This will have a voltage on it. The power level will be no more and perhaps less than the voltage on the capacitor. Another clue to the power level is if the secondary wires are narrower than those that go to the mains. That will indicate that less voltage comes out.
OK what to do. Well most makers say that the transformer is a safety item so it has to be replaced with the same type or one which is approved by the maker. So you can either contact the maker direct or find a service center, (for the brand) which might order you a replacement, or take the transformer to Radio Shack with details of the model number of the Sub, and see if they can get it for you. While there have a look at the multimeters. You should find one that will help you for all your future needs. I recomend one with a scale (rather than a digital). They are some around for £10 to £20 (I know you live in the USA but you can convert it) that will do what you might need it for.
The first thing to do if you get a meter is check with the ohm setting diodes or bridge rectifiers for shorts. IE: as if you had touch both probes together! Also do the same with any transitors you might find. As this could be the cause of the fuse blowing, and even the transformer's failure.
Mar 23, 2010 | Onkyo SKW-200 Subwoofer
Charger not powering up, fuse is good?? what the f---?
Internal board fuse checked? This may/may not help?
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the usual 240 Volt AC. On the charger circuit board next to the transformer wire connection is a component marked F2; this is a 2.5Amp fuse covered with heat-shrink sleeving. This fuse had ruptured/blown. Also blown was Transistor Q1, a ''P'' Mosfet labelled IRF9Z24N and Schottky Diode D9 labelled SR560. Replacing these 3 items got the charger working again. NB Resistor R31 is only 0.1ohm - don't assume it's gone short circuit! NB. I'd presume that most other Makita chargers will have this heat-shrink sleeving ''camoflaged'' fuse on the input of the circuit board and it would definitely be worth checking if the charger has stopped working. Regards Roy
Oct 24, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
One unit runs a while, powers down, other unit blows transformer
you say it keeps blowing the transformer? you mean circuit breaker? if it is the circuit breaker, have the wiring checked for a short, if no short do a ohm test on the compressor. it may have shorted out internaly.
May 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Charger no light and wont charge
Sorry to give you my opinion, but these chargers are very delicate, I have 4 and can barely keep 2 going. My recommendation? Open it up and look for obvious shorts/loose wires, if no luck then buy another one and return the busted one as if it were the new one. You will end up with two working chargers. PS this is probably fraud...ha!
Matt Giantglobes.com
Mar 10, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Drills Logo
339 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
