Question about Sub-Zero 245
My subZero Model 245 Icemaker stopped making ice
The Model 245 under counter ice maker stopped making ice. Water flow valve is on. Took the icemaker down and note some test holes in the control box but have no manual and Sub zero site is worthless. Any ideas or does anybody have a site where the manuakl caN BE DOWNLOADED?
  • 5 more comments
  • John St John Aug 21, 2006
    Thanks for this practical trouble shooting suggestion. I will follow-up this week and see what it yields.
    ""Best Solutionposted on Aug 21, 2006By catriver
    Rank: Wiz
    Rating: 84.58%, 144 votes
    Ice maker, I don't know where you can find the manual but I'll give you a few ideas of what to look for. First make sure that the inlet tube is not frozen over. Next, look at the center gear on the module and see if the clips in the center are not broken. If so you will have to replace the module. The ejector blades should be at the 2:00 position when home. If you get a jumper wire and jump T to H, this will by pass the bi-metal and run a cycle. The ice maker should fill at around the 12:00 position. Test points L & N will verify if you have 120v to the ice-maker. Test points L & H will test the resistance of the heater, 72 ohms. plus or minus 10%. Hope this gets you going, "
    What are the odds that the water solenoid valve has taken a dump? I would assume that if I have assured the water in-flow tube (about 1/2" dia) is not frozen, and my recollection is that it is not, then by following the "T to H"jumper cyle, if no H2O delivered, then possibly solenoid failure? Take it out and check static?
    Also, I had taken the electrical plug out a few times adn then reinstalled, just letting the unit lay in the compartment. I wnated to watch the gear to see if a cycle ensued. I came back later and hear d a noise and saw the cycle had taken place and there was a puddle of water! So I reinstalled everything, but since then, no ice cycle has occurred ...no noice like the cycle is happening? Any thoughts on this? WHAT ROLE DOES THE
    thermal fuse" play and can it go bad? Is it like a thermostat, not allowing a cycle if the temp is above some limit? (I have a wiring schematic from some past service reps work).
    THANKS FOR HELP< I'll update outcome.
    John
  • Anonymous Mar 13, 2014
    subzero ice maker overfilling with water
  • Anonymous Mar 15, 2014
    whirlpool refrigerater model number et8chmxko05 has stopped making ice.
  • Anonymous Mar 16, 2014
    ICE MAKER JAMS ON EVERY EJECTION, THER IS NO LEAKS IN THE ICEMAKER. IS THERE AN ADJUSTMENT TO MAKE THE CUBES SMALLER.
    icemaker has stopped making ice
  • Anonymous Mar 22, 2014
    the water stopped flowing an the icemaker stopped making ice
  • Anonymous Mar 30, 2014
    ICE MAKER LIGHT IS BLINKING AND ICE MAKER NOT WORKING
    President:
  • 878 Answers
Ice maker, I don't know where you can find the manual but I'll give you a few ideas of what to look for. First make sure that the inlet tube is not frozen over. Next, look at the center gear on the module and see if the clips in the center are not broken. If so you will have to replace the module. The ejector blades should be at the 2:00 position when home. If you get a jumper wire and jump T to H, this will by pass the bi-metal and run a cycle. The ice maker should fill at around the 12:00 position. Test points L & N will verify if you have 120v to the ice-maker. Test points L & H will test the resistance of the heater, 72 ohms. plus or minus 10%. Hope this gets you going, Catriver...post back.
Posted on Aug 21, 2006
  • Ron Marek
    Ron Marek Aug 21, 2006
    John, the temp in the unit has to be 17 degrees for the bimetal to close in the ice maker and cycle. You can rule out the valve by jumping V to L. If you get water, the valve is good. Did you look to see if the plastic retainer in the center gear is not broken? If it is the gear will be working its way off and the unit will not cycle right. Catriver...post back.
SOURCE:
Ice maker won't stop filling. Makes a little ice, but water is almost constant into the maker
The water control valve is shot. It's not making ice because there is a constant flow of water into the ice tray. Shut the water off at the feed point for the fridge for now. If the drain gets plugged you're going to have a small catastrophe on your hands.
Here's a procedure to test it to be sure:
How to Test Fridge Icemaker Water Inlet Valve Refrigerator Repair
Mar 20, 2016 | Kitchen Appliances - Others
Sub zero 245 stopped making ice, had service man out and he said wasn't getting enough water, and to replace cutoff valve and supply line and let thaw out. I did that and now have a water leak, but it is...
Most of the time the problem is the water valve that is electrically actuated by the ice maker controls. Remove the back panel and find the water valves and replace it. Many times sediment or wear and tear causes the valves to stop working properly or it becomes clogged with rust from the water pipes. If, the leak is at the ice maker then perhaps the problem is the water tubing alignment to the ice tray or the ice isn't dumping out of the tray, because the ice tray defrost element/ thermostat/ switch malfunction in the icemaker itself. It's difficult to find the cause without an experienced and competent refrigerator repair technician (such as myself) diagnosing the refrigerator onsite.
Feb 06, 2014 | Sub-Zero 245
Water started pouring out of the icemaker and out the dispenser. When we opened the freezer door water poured out of the icemaker and down the whole freezer. Opened icemaker flap and water stopped. Turned...
Cindy, it’s either the water inlet valve that fills your ice maker or the ice maker itself that is bad. The ice maker itself controls the valve. It should come on for about 7 seconds to fill the tray. The valves do fail but not as often as ice makers fail. Its also possible that the fill tube to the ice maker is blocked with frozen water but since it made one tray that is unlikely. If you know someone that knows how to test the valve it would eliminate the decision of replacing the ice maker or the valve. Otherwise I would recommend changing the ice maker first. Hope this helps.
Feb 11, 2018 | KitchenAid Superba KSRG25FK Side by Side...
Icemaker 200D1181G026 WR30X10061 model can15. Is there anyone who can test it and rpair it. It jst stopped working. Water supply ok.
The icemaker system on these machines requires 3 things:
A working ice maker. a working water valve, and 28 degrees or better in the freezer.
Nothing else in the frig controls ice production. Most times the water valve goes first. It is recommended to replace it when replacing the ice maker. Replace the water valve now and see if the ice production starts up. If it does not you will need to get a new ice maker, the old ones are not repairable.
IM6 Notes and fault codes
Refrigerator/Freezer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 01, 2011 | Hotpoint HSS25GFP Side by Side...
Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Mar 29, 2009 | Bosch KGU66920 Side by Side Refrigerator
Kemore coldspot no ice?
no you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Mar 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not making ice
this is from another post i did but will cover you too your ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jan 19, 2008 | KitchenAid KSRP25FN Side by Side...
Ice maker not workin
ok as far as the water in your door goes sounds like the micro switch is getting a little gummy and sticking this happens when people dump ice in sweet drinks and some splashes up locate the switch and spray a little wd 40 on it as to you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jan 18, 2008 | Whirlpool ED2FHEXN Side by Side...
Fridge freezer door ice maker
the ice maker controls the seloniod the icemaker wire arm must be all the way down .just because the seloniod test good doesnt mean the valve seat isnt stuck the water valves open by your house water pressure if your filter is dirty this can also lower the pressure if the icemaker module is bad this also can cause it if you pull the front of the ice-maker off you will se a bunch of holes if you get a piece of 10 Gage house strip about 1/4 inch off either side and insert it into the holes marked t and h that will test cycle the ice maker they will be close together don't get shocked if the ice maker cycles and doesnt fill and the ice maker fill tube isn't frozen replace the water valve if the ice-maker doesn't cycle replace the brown motor module
Jan 09, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
678 people viewed this question
Top Sub-Zero Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
