Question about Coffee Makers & Espresso Machines
Troubleshooting for Bodum Latte Milk Frother
I’ve had a problem using my Bodum Latte Milk Frother. The fact is that when the lid is placed on the beaker and the on/off button is pressed on, the frother doesn’t work as it is supposed to. The frothing wand stops working after a few seconds in operation, not moving up and down properly. The AA batteries that were used are brand new, and I don´t have any idea on how to solve this problem. Thanks for any help. Fábio, from Brazil.
  • 833 Answers
SOURCE: Steamer and milk frother not working
This sounds like one of several problems:
1. Does any indicator light come on? If there is one and it doesn't you either have a bad thermostat (size of a dime/1/4 inch thick) black item with two wires attached to the chamber or a bad heater. Check both with an ohm meter...Resistance of any kind across the terminals means okay.
2. Could be the switch. Same kind of test.
3. If you've got a steam leak, deal with cap or valve.
Make sure all wire fasters are clean and bright. If screwed down, make sure they are tight. Cycle each connector off and on to clean them.
Remember: always work on your unit with it unplugged. You may need torx screwdrivers to open this unit. Any hardware store will have sets of these items.
Posted on Jun 16, 2008
SOURCE: milk not frothing
called customer service. issue was, if you look at the hook where milk container connects,  you should see two rings, green  and black, if you don't this is what causing the issue.  they send me new once w/o questions asked...
Posted on Jul 19, 2008
I contacted Nespresso who may well replace the item
Posted on Nov 27, 2009
  • 21 Answers
SOURCE: My Nespresso milk frother did not come with
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Posted on May 08, 2010
SOURCE: My Nespresso machine is the
Have same problem with my Citiz
Posted on Oct 18, 2010
How do i change batteries on a bodum milk frother?
Well I don't really know what kind of frother is that. But try to call the customer service on where you have bought your frother machine.
Amazon com Kitchen Ace Can Opener Stainless Steel with Smooth Edge...
Aug 31, 2014 | Coffee Makers & Espresso Machines
The milk frother has stopped rotating.....the milk heats but the frother doesnt rotate hence no froth.... am in india,mmbai so dont know where i can fix it !
The solution to rotation issues with the frother have been soved finally by myself after reading all the suggestion. The fix is simple... Your attachments have been magnitised and need to be demagnetized. It works a beauty. Run a magnet around the metal rings. Hint. Never leave them on the the frother when not being used.
Jul 09, 2011 | Nespresso Aeroccino Automatic Milk Frother
It froth's milk beautifully but won't do soy milk.
We bought a Nespresso Milk Frother in 2010 for $100. The frother is the same one that comes with the Citiz machine but is a stand alone model. It froths soy milk very well. The less soy you put in it, the more froth you get but even if we fill it to the max line we still get a reasonable amount of foam. We use Silk brand soy milk. I have no idea if foaming is impacted by atmospheric pressure but it may be a factor to consider if you are using all the same factors as us but not getting great results. We live at a higher elevation Calgary, Canada in the foothills of the Rocky Mountains.
Sep 15, 2010 | Nespresso Aeroccino Automatic Milk Frother
Water Leaks from the head gasket while heating up to use steam
This is a result of the water temperature in the boiler increasing, thereby expelling water that may remain in the lines out of their respective exit points. A solution may be to place a container under the group head to catch the water, or opening the steam valve partially to allow the water to exit through the steam wand (again placing a vessel/cup/pitcher there to catch the water). This is a problem that even higher end (dual-boiler) models have, due to the necessary purging of water that accumulates in the steam wand during down-time.
Don't look at it as a problem, but simply as a quirk that single-boiler machines have. If you are still irked by the issue, consider buying an inexpensive manual frother (Bodum makes these) to froth and heat your milk (in the microwave after frothing) separately. An added plus is that you can do this while you make your espresso, so if you make primarily milk-based drinks (latte, capps etc.) you'll save on time.
Dec 21, 2009 | Saeco Starbucks Sirena Espresso Machine
Mr. Cuppacino milk frother manual
guess the problem is fixed long time ago? anyway i am happy to let you know if this appliance still annoying you.
i ve one which bought at laverton market some months ago, same problem as yours: no manual and even black and decker ignore my request to send me one. therefore i studied the construction and found out how it use:
1. fill up water to the level which engrave at the cylinder. (can fill hot or boiled water to save electricity and speed up the heating process)
2. when it boil power will off automatically, remember do not overfill to leave room for the generated steam;
3. plug off the power; pull up the looped pin of the bend tube;
4. place your milk jug (of course with milk or soy filled inside may be half full only);
5. press the grey button on the cylinder top (use some more energy; i know it is hard!) steam will come out to frothy your milk. 70c for latte, or 85-90c for cuppancino something like that.
hope this can help!
Nov 29, 2009 | Black & Decker Coffee Makers & Espresso...
How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
Aug 09, 2008 | West Bend (58036) 36-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
53 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
