Question about Casio Music
Casio HT-700 won't turn on, most likely short-circuited
I plug in my keyboard, but it won't turn on. I move to another outlet and plug my keyboard into that. It emits a low-volume buzzing sound, but the power light doesn't turn on, nor can any music be produced. When I turn it off, I smell speaker (by that, I mean the smell electronics produce when they are on for a long time and you smell it up close).
What components need to be replace and how do I do so?
2 Suggested Answers
  • 5603 Answers
SOURCE: looking for a schematic of the Casio ctk-700 to
The keyboard is LIKELY scanned as a matrix.
You have two problems:
The contacts in the Thomas will have to be totally disconnected rendering use of any of the Thomas organ unlikely.
The second problem is that the keyboard LIKELY has velocity sensing. This means TWO contacts must be used PER note. One contact "makes" first and "breaks" last. This is used for velocity sensing on synths. The Thomas foot pedals likely only have a single contact per pedal, and even if they had two, it is unlikely they sequentially close..
The matrix scanning is accomplished by sensing the connection of two crossing points on a matrix of circuit lines. USUALLY each of 12 wires tie to all of one note across the board. Then two other lines for each octave "strobe" the first make contact and then the second of those strobes the second make contact. There are two of these strobe lines for EACH octave on the board.
Remember that these lines scan at digital logic speeds so wire length and NOISE/STAIC DISCHGARGE PROTECTION is a must.
Posted on Aug 28, 2009
Casio LK-100 keyboard is turning off often when chords are played, esp in lower octaves - seems like a short. Where might the short be - way to fix without taking the whole keyboard apart?
Sounds like a lack of power from the external "wall wart" power supply. Is it the correct one that can supply enough current for a chord to be played? (a chord will play more notes at the same time & pull more power from the supply in order to make the sound(s)) If it's the correct power supply or one of the correct current rating check the cable & the connector both at the end of the cable & where it plugs into the keyboard. Perhaps the lead has been tugged accidentally? / Damaged in some way? Turn the volume down a little & see if that helps - that will confirm the power theory :-) Good Luck!
Jan 17, 2017 | Casio Music
What do I need to do with my Casio CTK 700 which will make it run on batteries?
If you turn it over, you will see the battery compartment. It runs on 6 AA batteries. Here's a link to the manual. Instructions are on page 13.
http://support.casio.com/pdf/008/ctk_496_700_e.pdf
Feb 25, 2015 | Casio Music
Casio keyboard won't power on
If batteries or power adapter does not power up the keyboard...possibilities are...if it has a fuse inside or fusible link check it.replace if blown.Another possibility is power component has a short. maybe from constant movement of power plug into keyboard.sometimes just by inserting the plug and wiggling it can solve the issue..having this fixed by a technician can cost a lot of money.but,if your keyboard`s value is less than the cost of fixing it,might as well replace your instrument.
Feb 21, 2012 | Casio 76 Key Smartmedia Keyboard
Casio ht-700
You may view the manual here.
Jan 25, 2012 | Casio Music
Casio ctk-501 the power input cracked on the curcit board i did a bypass wiring over the crack and it got power works again but only till i start playing a bunch of keys then the sound gets stuck and the...
When wiring around circuit board cracks, one must use adequate sized wires and keep the leads short. Also you MAY have a microscopic crack in yet another conductor that flexes when you play the keyboard and freezes it. Use a high intensity LED light from the topside to "candle" the board and look for cracks. Look for cracking of the board material that may have tiny cracks in the circuit traces.
Nov 17, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Hi there, When I am trying to plug in the adapter jack for my Casio Privia, my keyboard is not turning on. I have tried putting the adapter chord in several outlets to no avail. This is a new problem. Do...
First thing is to get a meter and verify that the power adapter is producing voltage that it is supposed to. You can get inexpensive meters at Harbor Freight for example. I am not sure what you mean by "several outlets"... I HOPE that is not several on the Privia because there is ONLY ONE correct place to put the adapter cord into the Privia.
If you mean wall outlets, verify them by plugging in a known good lamp or appliance to check the receptacle is good.
Feb 16, 2011 | Casio Music
Looking for a schematic of the Casio ctk-700 to
Aug 22, 2009 | Casio Music
Sustain pedal on Yamaha DGX not working
I had the same problem, its to do with the polarity of the pedal. My pedal had a polarity switch on the bottom just flick this over and this should fix the problem. Otherwise another solution was to hold the pedal down and turn the keyboard on.
Jul 18, 2009 | Yamaha Full-Size Keyboard
Music Logo
130 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Piyal Perera
Piyal Perera
Are you a Casio Music Expert? Answer questions, earn points and help others
