Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction on my dyson dc07 vacuum
It sounds good but I have no suction
AceKiller
  • 7 Answers
SOURCE: No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
Posted on Nov 07, 2007
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
SOURCE: Dyson Dc07
I had the same issue and solved it easily.My experience is the same as the March 6th response/ When you push your foot onto the base and then recline the handle, use your toe to gently push the very front of the base down closer to the carpet. This creates a much stronger seal and suction and picks up every bit of dirt easily. If i do not do this extra step the suction is much much less. I tried an experiment with sand that I poured onto my carpet. Initially, I went over the sand 4 times and the dyson 07 would only pick up 50 percent of the sand. I then poured more sand onto the carpet, and this time pushed the front lip down so it was contacting the carpet. This time only two passes were needed to completely **** up all the sand. Not sure why this is not in the manual but it really works. Good Luck!
Posted on Jun 29, 2008
SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
Posted on Jan 24, 2009
  • 5 Answers
SOURCE: dyson dc07 yellow/blue no suction at base
Sounds like you've **** up something which is obstructing the suction from the brush bar. There's a little section of curved grey pipe near the base which carries the dirt from the head up the vertical pipe at the back. This section can be removed, check there is nothing jammed in there, paper etc.
Posted on Aug 12, 2009
I have the DC07 model in the upright position suction is fine but when I drop the handle and go to vacuum it has no suction I've cleaned the filters and hoses for debri and still no suction and once I put...
Hi Chris,
I am very sorry to hear about this issue with your DC07 not picking up correctly. In most cases we may be able to resolve this issue by speaking with you directly and performing basic troubleshooting steps.
Please contact our US Dyson Helpline toll-free at 1(866) 693-9766 or our UK Support colleagues at 0800 298 0298.
Best wishes,
Jay
Dyson Customer Service
Oct 05, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction! cleaned it, and still no suction!!
It's almost certainly a clog. Here's the Dyson page which shows you how to remove a clog from 8 possible places.
http://www.dyson.com/support/help.asp?article=528&product=DC07-SY-HEPA_US
If you found this useful, please vote.
Feb 24, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I just bought a used Dyson DC07. Works good but
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 bagless - upright mode v poor suction, wand mode ok
From your description of the problem, it sounds as though the bleed valve is activating which only happens when there is a blockage.
We would recommend following the full blockage through as outlined in your user guide or in the Support section on our website at www.dyson.com.
Kind regards
Darran
Jan 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
We have the pink dyson and we have washed out filter, but it sounds like it is sucking air and it will not pick up, what would you suggest we try nest
You need to replace the belt. If the belt is stretched, worn or broken it will not pick up well, even if there is good suction. Here is the belt you need and the manual which has instructions:
Dyson DC07 Belt and Manual
Dec 28, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 animal bagless
You probably have a blockage somewhere in the hose or in the base where the hose goes in. Remove the plastic tube at the base of the hose by simply unclicking it and remove the obstruction.
Nov 07, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction
Hi.
If you have checked & cleaned all filters & its still no good go to this site http://dysonmanuals.llc.nu/index.htm
Then contact page you require DYSON DISC (1) DC07 NO/POOR SUCTION O/HEATING.
This will sort out your problem.
May 06, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Oct 24, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
54 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
