Question about Garmin Nuvi 1300 GPS Receiver
Garmin Nuvi 1300 will only display USB mass storage mode
Received emails about updates but was afraid of losing data. Any way my Garmin just shut off by itself today and when I try to turn it on it is in USB mass storage mode. I cannot get it to do anything else. Any suggestions?
  • 3422 Answers
SOURCE: Reboot the Nuvi 360 to "Mass Storage Mode"
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
Tray on PC (Lower Right)
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
position
Posted on Sep 30, 2008
SOURCE: garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Posted on Jun 17, 2009
SQUIRESXX
  • 486 Answers
SOURCE: i have a garmin nuvi 1300 and then i turn it on
it should show "loading maps" try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update, if not contact supplier for fix/replacement
Posted on Dec 27, 2009
SQUIRESXX
  • 486 Answers
SOURCE: Well my Garmin nuvi 1300 was working fine
it sound like someone has "unticked" maps go to settings then maps and map info and look for the screen that says city navigator, and tick box that should work unless someone has attached to pc and wiped maps
  • 1514 Answers
SOURCE: My garmin nuvi 1300 keeps
There's a solution to your problem at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
The article deals with all possible reasons for there being no map data available but if your satnav is working other than that it may be just that the map is not selected. If you can get into the menus first try selecting the map by
pressing TOOLS
then SETTINGS or LOCALE on models that don't have a settings menu
Press MAP and then at the bottom of the screen press MAP INFO
Your map name should be there and a box with a tick beside the name.
If the box is not ticked press on the map name and it will cause the tick to appear. This might solve the problem. If not the map is probably locked. You'll find details of how to unlock the map at the above link.
Posted on Jan 06, 2011
Mass storage mode usb
Common problem with this model is a loose USB port. More info on USB port issues can be found here:
http://www.sharc.net/gps_charger_repair.htm
Nov 11, 2013 | Garmin nuvi 1350 Car GPS Receiver
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
Garmin shows picture of computer
When the Garmin shows the picture of a computer, it means that the Nuvi is in mass storage mode. This mode is used to load software and map updates to the Nuvi and will usually go into this mode when connected to a computer or improper USB cable.
If this is occurring when it is connected to the vehicle power cable, chances are that the vehicle power cable is the wrong one.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
Feb 23, 2012 | Garmin nuvi 1450 GPS Receiver
My Garmin Nuvi 250 w gets stuck on the screen showing a picture connecting a computer to Garmin. I have it in my car and resetting hasn't worked. any suggestions
The nuvi is being put into mass storage mode (the mode used to transfer data back and forth to a computer). This is usually caused by using the wrong vehicle power cable.
The correct cable is Garmin part number 010-10723-06.
http://www.gpscity.com/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi.html
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
Garmin 265 wt is charging via USB cable.It will not connect to the garmin website.
The Garmin Communicator Plugin needs to be installed on your computer.
http://www8.garmin.com/products/communicator
Also check to be sure that the data cable is the correct one.
When connect between the nuvi and the computer, the nuvi should show that it is in mass storage mode by displaying a computer on the screen.
The correct cable is Garmin part number 010-10723-01.
http://www.gpscity.com/garmin-usb-pc-cable.html
Aug 18, 2011 | Garmin nuvi 265WT Car GPS Receiver
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuviĀ® 200 Car GPS Receiver
Screen is stuck on loading maps screen, garmin nuvi 1200
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
  • The device powers on and freezes at the Garmin logo with no trademark or copywrite info displayed on the device which normally shows up below the logo. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and freezes at the Garmin logo and then flashes a white screen briefly. The device then begins a loop of showing the Garmin logo and then flashes the white screen over and over again. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and then freezes or shuts down when displaying the Loading Maps screen.
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
  • Market Name: On the Road
  • Serial Number (listed on the bottom of the device)
  • Question Type: Repair Information
  • Provide a short description of your problem or question: nuvi frozen on Garmin Logo
  • Full Name
  • Contact Phone Number
  • Shipping Address
Nov 11, 2010 | Garmin nuvi 1200 Car GPS Receiver
My garmin nuvi 1300 shuts off on its own...attempts to load maps and restarts...what could be the problem
  • Full Name
  • Shipping Address
Nov 11, 2010 | Garmin nuvi 1300 Car GPS Receiver
While driving my Garmin will just shut down. It acts like a cord is not plugged in tightly but they are. Have to restart & call up recent address to keep going. I'm on vacation so I don't have any ID...
A Garmin Nuvi 1300 that won't start, freezes, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Mar 27, 2010 | Garmin nuvi 1300 Car GPS Receiver
My Garmin 1300 suddenly went to night screen for a couple of seconds and then shut off while driving. And now it won't turn back on even though there is power.
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Feb 10, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin Nuvi 1300 GPS Receiver Logo
322 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
