Dryer latch is broken
SOURCE: maytag quiet series 300 - model MDBH970AWW door
remove the inner door panel and control cover, switch will pop out after that
SOURCE: broken door latch whirlpool ghw9100lw1
The following link explains how to replace the door latch on a Whirlpool front loader:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
This is a very simple repair. I'm surprised at the cost of the labor you were quoted. An experienced technician can replace one of these latches in 30 minutes or less.
An alternate method of the replacing the latch is the remove the top panel of the washer and work down through the top. Due to variations in design features between models, this isn't always possible. If you want to remove the top panel, just locate and remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. If you have access the latch assembly from the top, you can attempt the repair using this method.
If you have any questions, please let me know. I hope this helps you.
SOURCE: Broken latch cable on 2000 Tundra, will not open
remove the door panel, i believe the handle uses a cable on the link... simple fix
SOURCE: dryer door latch mechanism broken.
Mine has done the same thing. The part (door catch) is easy to fix yourself. If you contact a local appliance parts store in your area and give them your model number they can order a new one. The part was only $4.76 + tax for me. You can pop the old one out with a putty knife and the new one, you just press in. Very glad that I had an appliance company that HONESTLY told me that this was something I could do myself. Good luck!
SOURCE: Front door forced open and latch broken. How do
The following link explains step-by-step how to replace a door latch on a Kenmore Elite front loader:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
Replacements parts (if required) can be purchased from any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please let me know. I hope you find this information helpful.
