My Sharp AR-M150 says system erro [L1-00] please what do i need to do?
  • 16 Answers
SOURCE: system error in sharp copier machine
Chip error on the toner cartridge.
Maybe incorrect region cartridge or could just have done its life if the cartridge has been refilled.
Replace the toner cartridge
Posted on Jul 07, 2009
hamzaskilltd
  • 316 Answers
SOURCE: I use Sharp AR-M150 3-in-1 Copier. I was scaning a...
heat roller low temperature detection
Posted on Jun 12, 2010
  • 2072 Answers
SOURCE: i have Sharp AR 5316 L1 00 error in my copier pls
L1 00 Content Scanner feed trouble.
Detail The scanner does not complete feeding in the
specified time.
Cause Mirror unit abnormality.
The scanner wire is disconnected.
The origin detection sensor abnormality.
Mirror motor harness abnormality.
Check
and
remedy
Use SIM 1-1 to check the mirror reciprocating
operations.
When the mirror does not feed.
Check for disconnection of the scanner wire.
Check the harness and the connector between
the mirror motor and the MCU PWB.
Replace the mirror unit.
Replace the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home position
Posted on Jul 28, 2010
  • 2072 Answers
SOURCE: sharp ar-m205
L1 indicates the laser mirror motor is bad. The laser would have to be replaced to fix properly.
Posted on Jul 30, 2010
Testimonial: "you mean small sensor black color ,right. If yes u have the part name and part number thks for good support"
hamzaskilltd
  • 316 Answers
SOURCE: i Have Sharp AR 5316
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 00-The scanner does not complete feeding in the specified time
Posted on Aug 07, 2010
How to fix sharp ar m150 system error (h4 00) refer to user guide
H4-00 generally means low temperature of the fuser. Check heater lamp, thermistor touching fuser drum surface, contacts and connections. It can be an electronic module failure, can require repair/exchange.
Apr 27, 2017 | Sharp Office Equipment & Supplies
Sharp AR-m150 refuse to copy, print and scan asking for user guide system error (H4-00)
error is sometimes a way for the machine to go into safe-mode when there is power fluctuations , or a problem with the machines thermistor or thermostat
Aug 04, 2013 | Sharp AR-M160 Black and White Copier
System error H4-00 sharp AR-M150
Paper jam error how to solve that error.. please help me
Sep 22, 2011 | Sharp AR-168S Copier
AR-M150 shows h4 but it does'nt have interrupt key
There is need to solve the low current problem by simply rectifying it frfom the power supply.
enter simulation (use SIM14) 'C' 'auto' 'C' 14 copy key
Jul 16, 2011 | Sharp AR-M160 Black and White Copier
HELLO I NEED SHARP USER MANUAL FOR DIGITAL AR-M155 PHOTO,PRINTER,SCANER,AND FAX. PLEASE SEND AS SOON AS POSSIBLE
Here's the manual: http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/AR-M150-M155-_E
Click on the "Download the complete user guide."
Fill out the four question survey or put in the security code to download file.
I tested to confirm that this is the right user manual.
Thanks for using FixYa.
Mar 16, 2011 | Computers & Internet
Simulation code for sharp copier ar-m150, diagnosis code list
Press & hold "0" key for total count.
Press "Clear", "Interrupt", "0", "Interrupt".
OR
"Clear, "0", "0", "Clear".
OR
"Clear", "Repeat", "0", "Pause".
Jan 28, 2010 | Sharp AR-5320 Black and White Copier
416 people viewed this question
k24674
jasbo
jasbo
