Question about LG 24 in. LDS 5811 Built-in Dishwasher
Build up in dishwasher
My GE dishwasher quit draining. The repairman said it was due to build up from the dishwasher soap I was using. I finally got a new one, a LG, but don't want the same thing to happen. Which kind of soap should I use, the liquid dishwasher soap or the powder kind?
  • tdbanister Oct 27, 2008
    Thanks for your help!!! I appreciate it. I will use the powder kind.
    President:
  • LG Master
  • 2,651 Answers
Powder works best in d/w. breaks down better in hot water application.
Posted on Oct 26, 2008
I have a Bosch dishwasher. I am getting a very large build up of crust on all the parts to the point that it clogs up and won't drain. This white build up is so thick at places it is past like. Help!
Dishwashers do not drain a such. The water has to be pumped out so it important that you don't do anything that will interfere with the efficient operation of the pump.
1. You need to pull every movable item out of the washer (baskets and the water filter units at the bottom of the washer) and give them a good clean. Then clean as much of the white gunk you can out of the machine. This is a build up of soap residue and may include undissolved soap.
2. Then run the machine while empty through 2 complete wash cycles with maximum hot water temperature to clean what remains out of it. Do NOT use any dishwasher powder while you are doing this.
3. The problem you have can be due to
- poor quality dishwasher soap powder being used or soap products completely unsuitable for dishwashers are being used
- too much soap powder product is being used
- the water temperature in the machine is far too low. In that event the water heater unit in the machine may be faulty.
Whatever dishwasher powder you are using I would change and buy a better one and also use less than what you have been using in each wash up to now. I would also STOP the machine in the middle of the wash cycle, then open the door and check the water temperature. It should be so hot a wall of steam should rush out when you open the door.
Jan 02, 2016 | Bosch Dishwashers
GE Quiet Power Dishwasher Model GSD4060N20SS.Leaving debris/food all over dishes after final rinse. I have tried to find online a repair manual or any info that tells me exactly how to locate and...
Cleaning the drain filter will help. Take out bottom rack. Turn filter and take out and rinse off in sink with soap and water. Replace. http://m.youtube.com/watch?v=OTfBAEmCVDo&desktop_uri=%2Fwatch%3Fv%3DOTfBAEmCVDo
Aug 15, 2013 | GE Dishwashers
Danby Dishwasher stuck in drain cycle after wrong soap use
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Dec 10, 2009 | Danby DDW1805W Designer Series...
It leaks very sudsy water all over my floor through the door. I think it is clogged and not draining properly.
very sudsy? 'automatic' dishwasher soap should not do this. if you are using 'hand' dishwashing soap, use 'automatic' dishwasher soap. if you are using 'automatic' dishwashing soap, try another brand. suds are for people to look at. 'automatic' dishwasher soap should not do this. good luck
Nov 01, 2009 | GE 24-7/8" Convertible Portable Dishwasher...
Cloudy glasses with hard white calcium build-up
the problem is not your dishwasher or your detergent. the reason for these spots is hard water. www.dishwasherfilter.com makes a new product to address and fix this problem. it filters the water going into your dishwasher leaving your dishes spot free with every load. it is very affordable and fits right under your sink. it is guaranteed to work or your money back. you will love this product. thanks
Apr 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Mar 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Dishwasher
Hi tucker19,
I'm Harvey the Master Plumber.
Your question is: You just purchased a GE Dishwasher from Home Depot...Its a QuietPower3...and after you run it, there is detergent build up on the detergent dispenser lid and residue on dishes...HEAVY RESIDUE...Why????
Are you useing a dry soap? If so, try a liquid. Make sure it says DISHWASHER soap on it. Also, use half as much liquid as the dry. Some new d/w's can be tempermental that way. If it persists then use the warranty.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
It doesn't work--there is an error message OE or it just beeps & shuts off w/o cleaning the dishes.
If you can get a repair-man to come out at least once or twice more and the problems aren't solved, you definately need to get on LG's case and have them replace it. My LG dishwasher was repaired about seven times before LG would do anything. I bought mine from an appliance dealer and they even had to fight just to get a response from LG. When LG finally agreed to replace the dishwasher (about a year after all the troubles began) my retailer allowed me to choose another brand of washer. I'd recomend a KitchenAid or Whirlpool, they have performed well in my home in the past and currently as well. The problem with your dishwasher right now is likely the motor. It seems to be the big thing that goes on all theses dishwashers. For me the motor was the last part to fail, it was having a hard time draining, the soap was not being disolved, and the dishes were always coming out dirty. My repairman told me that the LG products have been **** and he wouldn't recomend them. He told me this as long as I made sure his boss didn't find out. Good-luck with your fight against LG Customer Service, I hope you manage to resolve this faster than I did.
Apr 08, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher----GE Nautilus
1. Check drain pipe, air gap and drain for blockage.
2. Could be too much dishwasher liquid build up (i.e. too much Cascade used over time, clogging things inside the machine). Remove all standing water first then boil a big pot of water (3 to 4 quarts) and carefully pour in to bottom of dishwasher. Let stand until cool. Attempt to drain.
3. Turn off Circuit Breaker to dishwasher. Open kick plate at bottom and look around for the cooling fan for the motor and spin it free in both directions. Look for any solenoids and push them in to the other position. Attempt to drain on dishwasher.
4. If the above steps don't fix it and you are not handy, it's time to call in the repairman or consider getting a new one. If you are handy, do a web search on more detailed solutions for your model of dishwasher (typical failure points are valves, impellers, pump etc).
Dec 27, 2007 | Smeg 24 in. DWF614SS Stainless Steel...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
220 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
