Question about Ovens
How do I replace grill element in Tecnik TKC1285 oven
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: I have just replaced a
Sounds to me like it is wired incorrectly, the fan should continue to run even thnough the element turns off at the correct temperature setting.
You could try reversing the connections to fan and element, this in theory should solve the problem.
Posted on Dec 31, 2010
Grill on my tecnik tkc8525 tripping out my house electric. Any ideas ?
Probably heating element goes to ground when heating up. Suggest changing element.
Nov 10, 2014 | Tecnik TKC8525 Double Oven
The oven on my fan assisted Tecnik take a long time to warm up when on full power. is the element broken?
it dose sound like element but then could be stat...have your element tested if ok change stat...07779933829 uk
Feb 23, 2011 | Tecnik Ovens
Main oven trips electric when switched on top oven works fine also grill . did notice that fan was making a noise
If the fuse or circuit breaker is tripping it is most likely a short circuit in the oven element.
Feb 09, 2011 | Tecnik TKC8082 Electric Double Oven
I have just replaced a fan oven element on my Tecnik TKC1285 range cooker. However, the fan now turns off when the oven reaches temperature, and the element continues to operate
Dec 31, 2010 | Ovens
Hi there, The cooker trips the fusebox rcd,I have checked for s/c's between l,n,e, but found none. The rcd trips after you set the clock and turn the main controller to any postion,ie oven light only, or...
It is quite possible that it is the oven or grill element that is causing the problem.
You need to test them with a meter, to determine if they are o/k.
If you have no meter, then disconnect each one in turn, and try it again, this should isolate the problem.
Hope this helps you.
Dec 19, 2009 | Tecnik TKC071/3 Electric Single Oven
Bottom oven not working Tecnik 8525/2
To be certain the element is o/k , you need to test it with a meter.
The fact that it looks o/k proves nothing. If you know how to use a meter, then remove element from oven, and with the meter set on the continuity range, test across the terminals of the heater, if you get fsd, ( full scale deflectoin) then the element should be o/k.
If no deflection , then element is no good.
If in doubt, remove the wires from the element , and try the oven, if it does not trip, then it proves element faulty.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Tecnik TKC8525 Double Oven
Grill broken only part working
You need to replace the complete element
Dec 24, 2008 | Tecnik TKC8525 Double Oven
Main oven not heating.
Hi, Is this your fan oven element that is not getting heating up? If so we have a guide on our site which may be of assistance: http://www.ransomspares.co.uk/fan_element_article.html
Mar 01, 2007 | Tecnik TKC8085 Electric Double Oven
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
