Question about RCA RP7913 Personal CD Player
Problem getting started
My cd player will not play and displays an Hd and a small what looks like a skleton key....?
0 characters
1 Points
My cd player stops while playing and shows er on the display
Try checking for dust on the laser eye, A fine, clean and very soft artists brush will do for cleaning or perhasp the CD has a miniscule scratch on the surface. You'll know if it is a scratch as the CD will always stop in the same place. CD's and DVD's should only be wiped clean with a very clean duster in the direction of from the centre hole to the outer rtim of the disc. Never ever wipe anything across the whole surface from one side to the other or wipe in a circular motion. There a quite a few products on the market that will help you keep you discs clean. Just google CD (or DVD) cleaner. CD's and DVD's are quite forgiving in how badly scratched they can be and still play. It only takes a small scratch or dent that can only be seen under magnification to deflect the laser beam off track.
Mar 15, 2011 | Memorex MD6451R Personal CD Player
Wont start the movie it keeps running but then says no disc
With the large variety of video formats available nowadays it's difficult to find a unit that plays them all. Chances are you want to play a movie you burned yourself, and though it plays on your PC, it will not play on the DVD player.
Try playing the disc on your PC, and then try different DVD units, perhaps pretending you're shopping for one and want to try your own movie. Chances are these new units may NOT play it either, perhaps because you're using DivX or Xvid two video format contenders on the PC because their codecs offer great compression and very good quality (small file size and even HD video).
If it works on your PC it's because you may have the latests codecs (codifier / decodifier) installed, since some of them may have installed themselves as plugins for your browser, or come as part of a DVD viewing program you may have installed, like WinDVD.
For the time being, watch the DVD on your PC and upgrade your player, if it's more than 2 yrs. old.
Aug 29, 2009 | Personal CD Players
Koss cdp4045 cd player won't regonize new cd
it might be to old if not make a copy of the disk try again if not get a new cd player for £3.50
Dec 31, 2008 | Koss CDP4045 Personal CD Player
When I put in a music cd and press play the word NO shows on the display screen anc cd will not play
is it a cd-r or rw? was it purchased from a non-retail store which might not have it in standard format used by cd players? Try it a pc and see if it works this would cause you to get 'no' response
Dec 05, 2008 | Craig (731398428915) Personal CD Player
Won't play
Look on your player for a hold button or switch. When you find it turn it off.
Aug 10, 2008 | Aiwa XP-V5260C Personal CD Player
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Mar 14, 2008 | Sony Walkman D-EJ100 Personal CD Player
Dvd player will not play
push enter key to play movies if play button doesnt work
Jan 17, 2008 | Personal CD Players
Insignia portable CD player model # NS-P3112
Look everywhere on the unit for a button that says hold or lock. Its usually on the side near the 'eject' or 'volume' buttons. Good luck!
Dec 24, 2007 | Insignia Sport lDM9700-2 Personal CD...
CD Player Acting Up
some cd players have a feature that is called intro. it plays typically the first 4 to 10 seconds of a song & goes to the next track. it does this to every song on the cd. see if intro is on your display or if it's turned on in the menu. i hope it works. good luck.
Jan 04, 2007 | Aiwa XP-R230 Personal CD Player
My CD player keeps flashing (F15) when I try to play a disc.
It means that the laser/motor module is disconnected. Open the player and locate the connection band of the module. It should be orange, about 1 cm wide and it comes out from under it. Push it HARD into it\'s socket. Make sure you don\'t leave sweat or grease on the electronic and test it. I hope it works for you!
Dec 05, 2006 | Panasonic SL-SX320 Personal CD Player
RCA RP7913 Personal CD Player Logo
16 people viewed this question
Top RCA Personal CD Players Experts
Todd Zettlemoyer
Todd Zettlemoyer
Are you a RCA Personal CD Player Expert? Answer questions, earn points and help others
