Question about Drills
I have a dd200 hilti core drill & the motor stopped working & i cant restore the reset switch
Cant reset the reset switch
  • 21 Answers
Sometimes the motor of it have something called CARBON BRUSH inside,, try to look at it and replays a new one,,,,it is the most common trouble of a drill when its getting old olready but still can be fix by your self..good luck its not to hard..
Posted on Feb 17, 2012
2 Suggested Answers
  • 123 Answers
SOURCE: I have a dd200 hilti
If you have not done it already put the motor in the 1st gear. this will give you the most torque. Try that while pouring a lot of water to it.
Worse case is you disconnect the bit from the rig. Drill a hole on each side of the barrel at the end that connects to the motor big enough to stick a big piece of rod or rebar through. With two people twisting on the rod you usually can get the bit out.
Hope this helps
Posted on Aug 20, 2011
I have a dd200 hilti core drilling machine, just yesterday the 152 mm core bit is jammed and i cant move, i can not take out the core bit, i know that the iron bar small pc. is blocking the bit but i do...
Hope this helps
Jul 23, 2011 | Drills
How to reset Active Torque Control in the handle of Hilti model TE76P-ATC Rotary Hammer Drill
Active Torque Control (only TE 76-ATC / TE 76P-ATC)
The TE76-ATC / TE 76P-ATC is equipped with the Active
Torque Control system in addition to the mechanical
torque limiting clutch. This system offers additional protection
while drilling by rapid shutdown upon uncontrolled
rotation in the axis of the drill bit, e. g. when the
drill bit jams due to hitting rebar or when the insert tool
is tilted unintentionally.
When the ATC system has become activated, the tool
can be restarted by releasing the control switch and reengaging
it after the the motor has stopped rotating
("click"-sound signals readiness for use).
Always choose a working position in which the electric
tool is free to rotate in a counter-clockwise direction
(as seen by the operator). If this is not possible, the ATC
system cannot react.
Mar 01, 2011 | Hilti Drills
Need on/off switch for Hilti TE 17 Hammer Drill
Parts for the TE17 have been discontinued for over 15 years. The switches and the oilite bearings for the motor were the first to run out.
Jan 07, 2011 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Hilti te92 starts up then stops after a little use
It could be the contacts on the switch are burning out. The 92 also had an electronic speed regulator that could be going out.
After you run the drill and it stops. Unplug the drill, take the handle off and apart. Feel the screws on the switch were the wires are connected. If one of them is hot to the touch that usually means the contacts are burning up.
Oct 06, 2009 | Hilti 3431126 SF 144-A CPC Drill/Driver
My hilti te 6-s stopped working trigger looks to be ok. wondering how to test trigger and motor to be sure niether is the issue. thnx
I would first check the cord to the switch and then the 2 wires coming from the motor to the switch to see if they have continuity. UNPLUG tool first. to be on the safe side remove the bottom cover 2 T15 Torx screws and look at the brushes also and while apart if you have compressed air blow thru all the openings. The switch is hard to check so I would check everything around it first and if OK I would say a bad switch.
Apr 07, 2009 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Drills Logo
320 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
