Question about Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85 Optical Drive swap
I need to replace the optical drive. I't's notone that comes out by unlatching, so the bottom cover has to separate from the keyboard/top cover.
I have undone all visible screws in the base, and snapped the edges of the bottom apart from the keyboard/topcover.
I cannot get the bottom and top to separate. There appears to be some kind of fixing near the rear edges of the bottom, but I cannot see any more screws.
1. Are there screws hidden under labels - if so which one(s)?
2. Do I need to remove the keyboard (as you do on some other laptops) first?
3. Is there some other fixing I've not found yet?
Cheers,
Ian.
  • 1 more comment
  • ianbatty311 Oct 27, 2008
    Umm... Nup.
    I removed fifteen screws from the bottom casing (and two from the rear). I have undone all the snaps around the case, and I can lift the top, but it's still not coming off.
    If I flex the bottom case, it appears to be attached somewhere just near the left rear (viewed from the underneath) near the sliding battery catch. It is on the left, but not at the front.
    I cannot find the "left latch" anywhere, unless you mean the battery latch. If it's *not* the battery latch, if your "left latch" just one of the small catches that holds the top to the bottom, or is it a distinct mechanism?
    Can you give me more exact directions, please?
    Cheers,
    Ian.
  • ianbatty311 Nov 07, 2008
    Hi, Irishmistgal sent some pix of cover and other parts removal on a Toshiba Satellite A85-S107 laptop, but they are of low resolution (maybe 50 DPI), and don't have enough detail to read. Enlarging doesn't work, as the detail has been lost in the scanning process.
    Can you send me some higher-res scans (preferably 150~300 DPI) , or let me know if the images exist on the Web anywhere?
    Thanks heaps,
    Ian
  • Rene Montesino Dec 09, 2008
    Iam also trying to separate the bottom casing from the top. Have removed all visible screws but they still seem to be attached somewhere near the modem.
    Does anyone know where I can get a hold of a parts manual, diagrams, anything for this computer? Toshiba has been no help whatsoever.
Toshiba Satellite A85 Optical Drive swap - 36ec1a1.jpgHi, this is not the best picture but its this751c93d.jpge only one I can find so far. and yes screws can be hidden underneath stickers I haveToshiba Satellite A85 Optical Drive swap - e3bbac5.jpgbefore.
e3bbac5.jpgsave these to your computer and use a photo program to enlarge them so you can see them.
I hope this helps.
Posted on Oct 27, 2008
    Scholar:
  • 40 Answers
This instruction is for all Toshiba A8 series.
There are 13 screws to remove, including the HD slot cover screw and the battery slot cover screw.
Lift up the back and left side of the top cover about 1 cm ( less than half inch)to release the left latch on the front. Push to the right to clear the volume control from the top cover.
Rotate the top cover and display assembly forward to release the right latch.
Turn the computer right side up and open the display panel.
Remove three black screws that secure the top cover
Be VERY, VERY careful ok ?
Thank you and good luck. *s*
  • Susan
    Susan Oct 27, 2008
    sorry that was me that replied. I was surfing for something else on this site.*s*I hope the pictures help.
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
My CD is stuck in my Toshiba Satellite A505D laptop slot, with no hole near the Eject button.
Look on the cover on the tray near the eject button. Should be a tiny hole.
Get something like a straightened out paperclip and insert it in to the hole and push firmly but carefuly. It's an emergency eject for a stuck tray.
Feb 07, 2012 | Computers & Internet
Replace slot dvd drive in toshiba p500
1) Remove ALL power.
Remove the AC adapter (Charger) and Battery.
2) Lay a static free cloth on the table, or workbench you are working on.
(Protects the table, and the laptop)
Laptop closed turn it over, set it down on the static free cloth, Bottom side up.
3) Locate the HarDDrive Compartment Cover.
(Sony's term is HDD Slot Cover)
Looking at the bottom of the laptop, this is the rectangular cover that sits vertical, at the Bottom/Middle of the laptop.
The DVD optical drive is to the Right.
Remove the two Philips head screws which hold the cover.
Remove the cover.
(It has tabs made out of the plastic cover, which are on the opposite side of the screws. These tabs slide down into the Bottom Cover of the laptop.
When removing the cover use care, and do not break these tabs off)
4) With the harddrive compartment cover removed, look at the Right side. There is a square depression next to the right edge, in the middle.
(The square may be colored Blue)
There is one single Philips head screw to remove.
Then the DVD optical drive tray is opened by pushing it's release button.
The tray is used to gently pull the DVD optical drive out of the laptop.
This is a link to a free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the 'paragraph' that starts with - Satellite A10. (A10 in blue)
Drop down to the 5th line. (Begins with M500 in blue)
Scroll across, and click on P500.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (P500) it may take up to 30 seconds, before the first page comes up.
At the top of the PDF file is the page number box. It is to the Right of the Down Arrow. Go to Page 188.
Or use the Bookmarks menu to the left.
Left-click on the + sign next to -
Chapter 4 - Replacement Procedures.
Then scroll down, and left-click on -
4.5 Optical disk drive
(The Adobe PDF file may be in a different format, when it comes up.
Hover your mouse cursor towards the Bottom/Middle.
In the bar that appears go to the far right, and click on the red Adobe PDF icon )
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 30, 2012 | Toshiba Computers & Internet
Need to replace cpu fan on Toshiba Satellite A85-S107 and can not get the laptop appart.
Remove the battery, unplug the unit.
  • Take off the hard drive cover by extracting the two screws that secure it and then taking it off. Take out the screw on the modem and wireless card cover and take the cover off. To remove the hard drive, shift it to the left to disconnect it from the motherboard and pull it out of the computer. Gently disconnect the Wi-Fi card antenna cables and take out the card. Extract the screws on the modem card, disconnect it from the motherboard, and then disconnect the cable to free it from the computer. Remove the optical drive screw, push the drive out of the laptop and then take it off. Extract the 15 screws out of the bottom of the laptop and turn the laptop over.
  • Open the laptop and fold back the LCD screen as far back as possible. Pry up the keyboard bezel (the plastic strip above the keyboard) by inserting a flat-head screwdriver or a spudger in the groove at the right side of the strip. Pull the bezel off the laptop. Extract the keyboard screws and fold the keyboard down over the palm rest. Release the flat cable that connects the keyboard to the motherboard and take the keyboard off the laptop. Remove the screws securing the LCD screen to the back side of the laptop. Disconnect the video cable and the Wi-Fi cable from the motherboard and remove the screws on the LCD screen hinges and then pull the screen off the laptop. There are four visible cables that are connected to the motherboard: the switchboard cable, the speaker cable and the touchpad cable. Disconnect all three. Take out the four screws from the top cover and pry the top cover off by running the flat-head screwdriver along the groove around the entire laptop and pulling it off. Now the laptop is completely disassembled to where the motherboard is exposed as the last remaining component.
May 05, 2011 | Toshiba Satellite A85-S107 Notebook
Error loading operating system amessage appear on toshiba satellite A15-S127 and operating system cd on dvd and it didn't boat from dvd what can i do? or how can i enter setup
So you have a potential problem with the hard drive and a known problem with the optical drive. Replace the optical drive first: it's easy (one screw at the bottom, another one underneath the keyboard - these are the only 2 screws holding the optical drive in). You can buy a replacement drive, new or used, on eBay for $10 - $20 delivered. After that, you should be able to figure out if the hard drive's problems are OS related or HW failure. HDD's are cheap, too. This model uses 2.5" ATA IDE drive (30 or 40G or you can go larger), figure 50 cents to 75 cents per gigabyte, and you'll be okay. Just don't pay tourist prices for these things....
Apr 21, 2011 | Toshiba Satellite A15-S127 Notebook
Cd/dvd stopped working checked my computer and the cd/dvd drive is not there
You may uninstall the Optical drive in the device manager and the remove upper and lower filters in the system registry.
Apr 24, 2010 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite U305-S2808 DVD replacement?
Optical drive removal varies among notebooks. Some have quick-release gadgets, which may be on the bottom of the notebook or in the memory compartment. Some have screws that need to be removed from the notebook bottom. On my Satellite Pro 6000, it's on the bottom, aligned with the drive, but halfway to the other side of the case. If this is the case, pop it out. Get the model number off of the drive; you may have to replace it with the same one. While most optical drive chassis are standard, the drawer fronts are different, and not necessarily exchangeable.
Mar 04, 2009 | Toshiba Satellite U305-S2804 Laptop
Replacing a cd-rom drive
Most notebook optical drives are not too bad, usually only 1 or 2 screws hold the optical drive in from the bottom. Remove the screws, pop out the drive and pop in the new one. For the drive, try here:
http://www.sparepartswarehouse.com/categories.aspx?devicetype=Laptop&partcat=CD-ROMs&vendor=Toshiba&modelline=Satellite&series=&model=
Check the How Do I Identify my model #.
Nov 01, 2008 | Toshiba Satellite L15-S104 Notebook
How to replace cd/dvd rom in Toshiba notebook Satellite A105-S1014
Steps for Removing and Replacing the Optical Drive
Steps 1 - Remove the battery
  • Slide and hold the battery release latch to the release position.
  • Lift the front edge of the battery and remove it from the battery bay.
Step 2 - Remove the optical drive
  • Remove the 7 mm P1 Phillips-head screw that secures the optical drive to the bottom of the notebook.
  • Use your finger to grasp the edge of the optical drive bezel and slide the optical drive out of the base enclosure.
Step 3 - Replace the optical drive
  • Insert the optical drive into the base enclosure until the connector is seated.
  • Replace the 7 mm P1 Phillips-head screw that secures the optical drive to the bottom of the notebook.
Step 4 - Replace the battery
  • Toe the rear edge of the battery into the base enclosure.
  • Lower the front edge of the battery and press the battery into the battery bay until the release latch clicks.
If you want to See the Video for replacing the DVD drive. You can go to this URL :- http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01271783&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Jul 05, 2008 | Toshiba Computers & Internet
Cd burner
How old is your optical drive now?
How often did you use that?
It is still under warranty?
if yes, contact your manufacturer to replace your optical drive.
try to check the connections between the optical drive to your motherboard.
if the system recognize the drive so i therefore conclude that your drive is identified and working properly.
this is the common problem with optical devices. I have 5 cd roms and burners. it only serves me about a year or two then. useless.
Feb 05, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Toshiba Satellite A85-S107 Notebook Logo
132 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
