Question about GE 27GT722 27" TV
GE model 27GT722
Need circiut board XX15509-48B. our cable connection broke off on the rear of TV.
  • 1 more comment
  • stiles31 Apr 20, 2008
    I am trying to purchase that same connector but having trouble finding it. Printed on it I find "CTF 5800" and also "04840375433" and also "21027220" and it is manufactured by thomson... but have yet to find it or a part that replaces it. Any help? good TV but worthless without a coax connection.
  • dozcar Apr 13, 2009
    Hi i hope someone out there can solve my problem.
    I have a RCA TV model#F25432 Chassis#CTC203AD5.The problem is i cannot recieve channels 2-6 & 14,15 during the channel search.Please help.
  • Algie St. Cyr May 11, 2010
    I have replaced the coax connector on many TVs. Sometimes you can even use the original connector. You have to solder it in , using a heavy enough soldering iron or gun on the ground of the connector after resoldering the inner connector to the tuner board. I have even just installed a pigtail of RG-58 coax directly to the tuner board with a coax connector on the end and secured the whole thing with Nylon clamps. This is a problem that occurs very frequently.
  • 3 Answers
You ****!!! You gave techman a bad rating because? Thats good as advise your gonna get you loser!
Posted on Aug 19, 2006
    President:
  • 3,130 Answers
Sorry, the board is not available as a replacement. That connector can be replaced by a skilled tech.
  • Larry  Dillon
    Larry Dillon Aug 20, 2006
    Now Now biney, lets not show we go as low as the peeps who ask Questions, as we cant fix them over the internet, anyway my magic wand is in the shop!! lol
Brought a GE model 27gt722 tv...can not pick up all channels on cable. Usually once you hook up cable wire to tv cable is automatically on ..at least that is how it was on old tv
Depending on the cable company, some like Comcast have gone mostly digital meaning when you connect the TV directly to cable without a cabe box you will only get around 35 channels. The only way to get around that is to get a cable box. If you have Comcast service already they offer what they call a DTV cable adaptor which will allow you to get most cable channels. These DTV adaptors in most areas are free for the first two per household. I hope that helps : )
Jul 25, 2011 | GE 27GT722 27" TV
Need Operators Manual for GE 27GT722
Found a manual online and that described the situation. Thanks.
Feb 08, 2010 | GE 27GT722 27" TV
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Can't get channels I just got cable
Call your cable company! Whoever installed your cable did not set up your remote or give you one of their remotes. Most of the time your tv must be set on channel 3 or 4 and your tv has to be set to cable. Then you can use your remote or the cable company's remote.
Nov 18, 2008 | GE 27GT722 27" TV
27GT722 Blows Fuse
There should be a part designation written on the board under that part. FOr example Qxxx or Dxxx. Can you post that here please? I can cross reference that designation using the model number to get you the part number, cost and description.
Dan
Sep 17, 2008 | GE 27GT722 27" TV
Channels not working
It was in the guide plus set up that I needed to redo. When I was originally using it I had it setup to be connected to cable box, but when we moved it into the other room when we got the new tv we recieved, there wasnt a cable box in there. I didnt know that I just need to reset the menus to delete it being connected to cable box and it worked. I hope this will help someone else if this problem occurs with their TV. Ron
Sep 16, 2008 | GE 27GT722 27" TV
27gt722 sound ok, no video
I found one of these that had an inductor coil which is in series with the hoizontal output transistor base open up. It had a bad solder connection where it goes through the circuit board. This might be what happened to your tv. If so, it needs to be resoldered. What happens is that you loose horizontal drive and since the voltage that lights the filiament of the picture tube is derived from the flyback transformer this voltage is gone. Another possibility is that you may have an opem filiament (rare) or a loose connection on the picture tube driver board which is mounted on the neck of the tube. Stargazer
Feb 23, 2007 | GE 31GT740 31" TV
GE 27GT722 Picture problem
Regarless of the reason I will give you ,call a service tech for an estimate since is the safe way to correct the problem. First when you loose the pix put your forearm in the face of picture tube and if the hair in your arm stands up is a good sign because you are not loosing high voltage to the picture tube but if the hair does not stand up it means the crt looses high voltage and for that you need a service tech to troubleshoot.The other reason might not be as expensive If you have high voltage by doing the previus test it might just be a loose conection in the crt board.Do not remove the back cover unless you know what are you doing.Is not safe.
Sep 14, 2006 | GE 27GT722 27" TV
Cable connector broke off at solder for GE 27GT722
Common problem Order 215543 from a company such as Union Electronics..1-800-648-6657 Use only the orginal, the replacement melts to quicky from the heat of the solder. They don't have a minimum order. Also make sure all the tuner shield grounds are resoldered. Be careful. easy to solder short.
Jun 28, 2006 | GE 25GT240 25" TV
Open Questions:
GE 27GT722 27" TV Logo
135 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
