Question about Toshiba Portege R700-S1310 13.3 inch i3-350M/ 4GB/ 500GB/ DVDRW/W7 Pro+XP Pro Notebook (PT310U01Q01QR700S1310)
Hello I have a Toshiba Portege r700 series Netboook and I installed windows Xp onto it. After installing xp it worked fine, all the drivers installed as well but the battery went dead and it shut down unexpectedly. When i tried rebooting it, it displays a blue screen of death. I went into the Bios and changed the configurationn from Acih to compatability mode and the system booted fine but the image was extremly distorted. What could be the cause of this and what can i do to fix this problem? thanks
    Master:
  • Toshiba Master
  • 126 Answers
Try Windows Safe mode When you tried rebooting
Posted on Jun 04, 2017
  • 263 Answers
SOURCE: Windows XP Cannot installed
try http://www.driverguide.com
Posted on Jan 05, 2008
SOURCE: Toshiba M55-S3512 After XP SP3 update, OS IS NOW MISSING
you can restore your system to the nearest back date
Posted on Aug 04, 2008
Basilio00920
  • 155 Answers
SOURCE: toshiba a200/205 series Hard disk is toshiba mk1246gsx need compatible driver for windows xp I need to convert my OS from vista to XP
Well... this is common on newer laptops. It is due to the fact your HDD is SATA (Serial ATA) and Windows XP CD does not have the drivers needed to recognize it. The solution I use is a bit High Tech: to remaster your Windows XP CD including the drivers needed. Or, just settle to live with Vista until January, when Windows 7 will be available to the public. If you are not faint of heart, google this: nLite; with this program you can remaster your XP CD. (You need a working PC with CD-RW to actually do the job).
Posted on Apr 14, 2009
leecom72
  • 4806 Answers
SOURCE: need drivers for windows xp
Hi there.
Sorry to say that there are no XP drivers for that model laptop, it only supports Vista.
Thanks for choosing FixYa!!
Posted on Jun 08, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Toshiba Satellite L310 problem , display cannot appears
If the screen went blank after the driver install, sometimes clicking the mouse on the screen will bring the picture back. It sounds like the monitor is having a conflict with the resolution the driver is throwing out. Reboot the laptop and when you see the Toshiba splash screen, tap F8 until you see the multiple boot menu. Scroll to Safe Mode with networking and reboot. If the screen comes up, go to the control panel > System > hardware > display adapter > click on the plus sign and double click the reported adapter.click on driver tab and select roll back driver > click yes to any prompts and click ok. Reboot normally and see if that clears the problem.
Posted on Sep 07, 2009
Setup did not found any hard disk installed+toshiba s100-s1133. While trying install windows xp
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
Toshiba Portege M400-S4031 Windows XP replaced hard drive SATA used restore cd from Toshiba after loading setup screen says finished and to restart but when restarted computer error (can not find hard...
.Thats because your restore cd does not contain the Sata driver. Go to toshiba site and find the sata driver. You will need a floppy drive (a usb one would be good). Burn the driver to a floppy and load it into the drive. Now when you start to install the restore cd at some point near the beginning you will need to tap F6 (it tells you at the bottom of the screen) which tells xp to look at the floppy. It will install the driver and continue installing xp. simples??
May 16, 2011 | Toshiba Portege M400-S4031 Notebook
I have a Toshiba Portege 3500 with rotating LCD screen, my problem is that I can not rotate the wiew of the screen. The settings were changed, and now I can not rotate the view again. Thanks for your...
Do you have Windows XP with servicepack 3 installed? If so then there is a known problem with the screen driver and XP sp3. Go bakc to SP2 and reinstall de display drivers this should clear the problem.
If anyone has working tident drivers for XP SP3 I would be greatfull!!
Aug 04, 2010 | Toshiba Portege 3500 Tablet PC
How to install Windows XP onto a newly formatted laptop
put winxp cd in tray
at boot up press F12 - right-arroweto CD icon --> Enter
winxp should go into install
you'll probably need a version of winxp that can recognize Sata hdd. or hae sata drivers handy.
Oct 13, 2009 | Toshiba Portege M200 Notebook
How do i instal drivers for my graphic card on laptop toshiba portege 4010.operating sistem is xp
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
You need to find the full model number to download the driver, but you can either do it on the laptop or another computer and transfer it to a thumb drive. Should be in an executable file or compressed folder. XP can open both using windows explorer by double-clicking.
Sep 23, 2009 | Toshiba 20GB 5400 RPM NOTEBOOK HARD DRIVE...
Toshiba portege 3500 tablet pc
You should contact Toshiba service and order a recovery CD for that model. You can also install any Windows XP version, but it will not provide support for the tablet functionalities, which means that you will have a notebook that is not a tablet.
Note: Actually the original operating system is Windows XP Tablet PC Edition 2005: It is Win XP Pro + Tablet PC software.
I have heard that Vista provides support for Tablet functionalities, but you may still have to buy it from Toshiba because of the drivers for the specific hardware.
I installed Linux Ubuntu on a tablet. The latest version of Ubuntu provides some support for the wacom stylus pen, but not much else.
Hope it gives you some leads to follow through.
Aug 27, 2009 | Toshiba Portege 3500 Tablet PC
M200 Tablet - cannot write on tablet
i lost my software that came with the system and want y
to install the operating system.
purchasing the software and install it. i downloaded drivers and yet the pen did't work.
Dec 05, 2008 | Toshiba Portege M200 Tablet PC
Installing XP on Toshiba Portege R500 Notebook
Guys, if you have the genuine XP CD, please download the Storage Driver from Intel and slipstream it into your version of XP CD. You can also slipstream Service Packs into it as well.
Personally I hate Vista so much. It really brings out the angry devil in me.
By the way, the best and easiest way to slipstream is to install and use nLite http://www.nliteos.com/
Let me know if you want help on installing XP on R500 (I build it a few days ago, but regret to update the BIOS to version 1.06 as I lost the Ctrl key on it).
To get to the BIOS, press and hold the Esc key then Power button.
Oct 03, 2007 | Toshiba Portege S100-S1133 Notebook
Unable to install Win XP on Toshiba portege R500
make the SATA disk mode from ACHI to Compatibility in the BIOS. once its done without any problem you can make partitions, installa Windows XP. hope this helped you. thanks.
Ammar.
Oct 02, 2007 | Toshiba Portege S100-S1133 Notebook
Toshiba Portege R700-S1310 13.3 inch i3-350M/ 4GB/ 500GB/ DVDRW/W7 Pro+XP Pro Notebook (PT310U01Q01QR700S1310) Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
