Question about HP Computers & Internet
Osd volume control won't go away
Monitor volume osd suddenly appeared dead center in the middle of the screen and won't go away, only button that works is the power button. holding down buttons on monitor for menu just makes blue power button flicker. simultaniously holding down menu and selct button brings up a monitor check sum dialog, then starts adjusting the colors by itself. I have never used the speakers built into the monitor. I somehow managed to change the display language to Chinese. I have sometimes managed to bring up the menu, but the up/down arrows are of no use..osd just does whatever it wants to do. I haven't had any previous trouble with this 4 year old monitor besides some annoying vertical lines on the side of my screen
  • 1 more comment
  • Brett Hemlinger
    Brett Hemlinger Feb 17, 2012
    I've never seen any mention of the monitor being locked, and have tried all the solutions presented on this site. short of opening up the monitor housing physically
  • Brett Hemlinger
    I thought maybe I had the problem solved by connecting another computer to the second hdmi input on the monitor, but after thirty minutes the volume control osd has reappeared. argh!
  • Brett Hemlinger
    Brett Hemlinger Feb 20, 2012
    Hannspree HF289H 28" widescreen monitor
  • HP Master
  • 20,706 Answers
Bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Posted on Mar 25, 2017
  • _-__-___-_
    _-__-___-_ Mar 26, 2017
    if i had it, id be all over that switch.
    one is stuck. id find a way to fix it
    or to replace it or defeat it or use kludged in added rear switch to replace, it.
    its just a switch.
  • _-__-___-_
    tricks, ?
    power off for 10 mins
    then holding the menu switch in ,
    power on, it might do a reset.
    or call the maker and ask for the secret reset method, all have service manual and covers this
    buy one getone, find one?
    not once did you tell the maker and model of this display are we to guess?
    our ONLY CLUE IS HP in the title.
    what is the HP service tag data.??????????
A white block appears in the middle of the screen... it says" OSD lockout" occasionally it will disappear for a moment, but then returns or a large black box that has "Main Menu" at...
Fix One: Plug in the monitor and power it up. Hold down the Powerbutton until you get a message saying "OSD Unlocked". If the problem persistsafter OSD is unlocked then unplug the monitor from the wall, wait 20 secondsand try again. Fix Two: Turn on the monitor and hold down the Menu button for 10-20seconds. This should unlock the OSD. Fix Three: Turn off the monitor, press down the Menu button and thenturn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Aug 10, 2011 | HP Pavilion w22 22" LCD Monitor
Philips crt moniter osd locked model 107e5
Can you explain the problem a bit more.
You are locked out of the OSD or the options are not available on the OSD. OSD won't go away?
May 11, 2011 | Philips 107E56 17" CRT Monitor
I have a Sherwood Nottingham R-925RDS receiver. No matter what input I select it does not connect to the amplifier section. Everything else appears to function ok. Unit switches on & off, correct...
Let's work with FM as that is ONboard and can't be connected wrong. Does THAT work?
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 06, 2011 | Sherwood Audio Players & Recorders
How do I remove 'OSD LOCKOUT' from my monitor/screen?
Try holding the power button or the menu button of the monitor for about 5 - 10 seconds. This should remove the OSD Lockout message. Consult your monitor's reference manual if you still have problems.
Apr 11, 2011 | Computers & Internet
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
Osd lockout and automaticv volume decreases on hpw1097 compaq com
Change the front control panel switch set.
this is the major problem
available in market
Aug 29, 2009 | HP Compaq WF1907 Monitor
The osd main menu has appeared on my hp pavilion f1703 monitor
Control Panel->System->Hardware->Device Manager->Monitor. select and uninstall. Then let Windows detect the monitor and re-install the drivers for your monitor. Do the same for the disply adapter in the Ctrl Panel.
Aug 24, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Problem with OSD Main Contorls unlocked/locked
Philips say "To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC."
Jan 29, 2009 | Philips 190B6CB/27 19" LCD
OSD lock - I think
This is for Viewsonic LCD, but it's probly pretty similar for you...
OSD and Power Button Lock Modes
OSD Lock This mode locks all current control settings and prevents access to
the control menus until this mode is unlocked.
? OSD Lock: Press and hold [1] and the up arrow  for 10 seconds. If any
buttons are pressed the message OSD Locked will display for 5 seconds.
? OSD Unlock: Press and hold [1] and the up arrow  again for 10 seconds.
Jul 22, 2008 | ViewSonic E70f 17" CRT Monitor
Computers & Internet Logo
170 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
