Question about Canon Office Equipment & Supplies
I have an older Canon BJC-3010 printer with no problems before, now it won't feed paper during printing (even though feed mechanism works)and says Error 5700. Please help.
    Scholar:
  • 69 Answers
Hello Bigdave,
I understand how it feels when things don't work.
The error 5700 occurs mainly due to hardware malfunction. The error occurs mainly when the paper sensor stops working or is damaged.
How ever try reseating all the cables and also try uninstalling and reinstalling the software. Hope this works. If the issue persists the only way is to get it serviced.
But I suggest yo to go for a new printer instead of servicing the old one as it costs you more than buying a new one.
Thank you. Best of Luck.
Posted on Oct 26, 2008
Canon bjc 3010 waste ink error
just clean your cartridge..align it properly when you it back..surely it put properly.
Feb 08, 2014 | Canon BJC 3000 InkJet Printer
Paper feed fault
Check the printer lens and make sure the paper is probely inserted. Hope this helps...
Jan 28, 2008 | Canon BJC 3000 InkJet Printer
Canon Bubble Jet printer won't feed paper and print properly.
Hello sir; You need to clean up paper pick up roller and feed roller with alcohol, if still have problem then replace it.
Nov 07, 2009 | Canon BJC-85 InkJet Printer
No paper feed if less than 20 sheets in hopper
I had the same problem & it was suggested to adjust the rollers. I took the cover off & played with them & they fell down from a "stuck" positiion. I then left the cover off, taped down the device that moves the cartridges to the center (black movable tab) and hand fed a sheet to see if it was printing OK. It worked so I put it back together. I noticed that the feeding chute extension (goes up) which I had never used before & put it fully up. After printing with a stack of papers and then just a few it now works well with a glossy 8x10 perfectly. I think the change in angle of the paper you get when the paper doesn't bend due to the extension it the key.
Apr 01, 2009 | Canon BJC 8200 InkJet Printer
I have a canon bjc 80 connected via usb to acer laptop with vista on says hardware successfully installed & sounds like it is printing but will not feed paper or print !! have not used a disc to install...
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge.
Feb 19, 2009 | Canon BJC 80 InkJet Printer
Printer always prin at the to of the page and then it will parer jam but no paper is in it to jam up I have a canon bjc-4200 and I like the print that it dose
hi there,
This problem mostly caused by another material (such as broken paper, etc) present in paper path prevent paper to reach paper cam sensor. Check inside your printer and clear paper path from another material. You can also try to clean paper feed roller. If problem still persist, replace paper feed roller
Regards
Source:
Canon Inkjet Forum
Nov 09, 2008 | Canon PIXMA iP1600 Printer
Printer problem
I found a small plastic "clip" of the type that covers the print-head of a cartridge in the mechanism where the printhead/inkcartridge is mounted. I have no idea where it came from nor how long it had been in there but the printer works OK after I removed it.
Jun 22, 2008 | Canon BJC 2100 InkJet Printer
Error light & 7 beeps
geez, going back in time,but it is a print position fault, head is not traveling correctly , make sure rail is lubed and carriage can move back and forth without obstruction,
Oct 26, 2007 | Canon BJC 80 InkJet Printer
No Print
remove the cartridge and set it on an alcohol-soaked paper towel in the kitchen sink for about 15 minutes. If the towel has not begun to draw ink out, then tap cartridge firmly against your other hand which is holding the towel. if still none, then try heating the alcohol to about 150 degrees and repeat. if still nothing, then ink is either spent or cartridge head is dried up. take it to cartridge world (or similar outlet store) and they can get a cheap replacement.
May 31, 2007 | Canon BJC 3010 InkJet Printer
178 people viewed this question
old marine
old marine
