Question about Sony Audio Players & Recorders
High Pitched Noise Coming from Sony STR-DH510 LCD Screen - how to fix?
I have noticed a high pitched noise for a few weeks now, and I was able to pinpoint the issue to the LCD screen on the receiver. When I change the dim settings for the LCD screen, the tone of the noise changes. It is the deepest on max dim and the highest pitch on no dim. Also, I plugged the receiver directly into the wall (as suggested by Sony support), and that did not change the high pitched noise issue. Are there any other possibilities that could be causing the high pitched noise? Any help is appreciated. Thanks.
  • Ben Boston Feb 20, 2012
    The problem is not with the TV; it's with the Sony A/V receiver model listed in the title. Do I need to open the receiver and check the backlight inverter board?
    Top Expert:
  • Sony Master
  • 75,599 Answers
Hello
The problem is with its backlight inverter board. there are some step-up transformeres [small ones] fitted on board. If any one's core bacome loose this fault will occur. Just open the TV and listen to which one makes hi-pitch noise. Replace it, if you can buy it from the electronic market at your town. In most cases, the inverter board needs replacement.
This board can locate on the right or left side of the panel, fitted vertically.
http://www.dataentryjobs.us/67948.html
Posted on Feb 18, 2012
5 Suggested Answers
  • 99 Answers
SOURCE: Hi. I can't seem
Subwoofer outputs on a Sony requre powered speakers.
Posted on Aug 31, 2010
iambanshee74
  • 3489 Answers
SOURCE: Sony str-dh510--I have very low volume from my
This model requires a "Phono" input. This will give you the best sound. Once you hook it up correctly, make sure the volumn is down or you will blow the amp.
Posted on Jan 01, 2011
dunnbiker
  • 8546 Answers
SOURCE: Can I connect a passive
No. Like most AVR's it only provides a Line Level output for an externally powered subwoofer. Get a separate amp for the sub.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Posted on Apr 17, 2011
dunnbiker
  • 8546 Answers
SOURCE: There is an intermittent, high-pitched
I've had variable track lighting cause a similar problem and only with analog sources. Is it only with track lights on?
Posted on Sep 22, 2011
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High pitched noise coming from back of Viore LC32VH56A. Not speaker related.
A refurbished set!
Its a coil or transformer that is not tightly mounted or is vibrating hard enough to make the sound, If this is a refurbished set that is why it was returned and exchanged-----
Two ways to fix---locate which board is bad and correct the problem with Hot glue on the individual part making the noise OR just replace that board.
Dec 08, 2012 | Viore LCD32VH56A 32" HD LCD Television...
Toshiba a215 s7444 high pitched noise
If the high pitch noise is coming from the bottom edge of the LCD screen, then the noise could be coming from the inverter.
Replacement inverters are available from :-
www.lcdparts.net
Nov 03, 2010 | Toshiba Satellite A215-S7444 Notebook
When turned on picture fluctuates and emits hig
The high pitched noise is coming from the Tcon board. It is not properly decoding the signal coming form the main board correctly. The only way to fix it is to replace the Tcon board. You might have a hard time coming across the part because Olevia has since gone out of business. Also, usually Tcon boards are not available sepertaly and most manufactures make you purchase the whole LCD panel of which the Tcon is included.
Nov 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
High pitched noise from inside the TV when picture comes on
Hello randapaint,
This might be from the IHVT (Integrated High Voltage Transformer), or more specifically a short in the IHVT causing it to arc, producing the high pitched whine, you are hearing. Take the back off of the TV and try to detect where the sound is coming from, more then likely you will notice it coming from the section that contains a large component with a large red cable coming from it, to the top of the CRT (picture tube). Replace the IHVT (with the exact same model) if it is bad.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 07, 2009 | Televison & Video
Buzzing noise from rear of 26inch sony flat screen
cheak back light settings turn it all way up if down to low it will buzz in video options
Oct 15, 2008 | Sony KDL-26U2000 26 in. LCD Television
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
365 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
