Question about Kitchen Ranges
Relatively new Blanco Bose 65 oven is is not heating when on fan-forced but heating normally wehen used standard. Grill etc all work. Driving me mad, thermostat issue?
  • Anonymous Apr 27, 2009
    Similar problem. Any solutions?
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
SOURCE: Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Posted on Jan 17, 2008
SOURCE: I have a chef premier
Suggest to fix problem by not bying electrolux products and possibly other well known brand names as well
Posted on Apr 13, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 6 Answers
    SOURCE: Smeg SUK91MFX5 oven wont heat
    Reset the clock that will make the heating element work, if your clock has stopped displaying (common fault) set as per instructions but you wont be able to set at any acurate time.
    Posted on Oct 04, 2008
    Fan oven not heating up
    This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
    • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped like us on facebook please
    How to Video Tutorials on Domestic Appliances
    Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
    My omega europa oven is not heating up .grill fan
    Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
    Mar 18, 2010 | Ovens
    White powdery stuff inside the oven, now no heat
    It sounds like the oven element has blown.
    The powdery stuff you refer to is the insulation of the element that has blown out.
    You will have to fit a new element.
    Please rate my solution.
    Thankyou.
    Feb 03, 2010 | Ovens
    Fan forced heat not working
    If it is an electrically heated fan oven, then it sounds like the oven element is not working.
    This is usually located at the rear rof the oven behind a removeable cover.
    Hope this helps.
    Dec 05, 2009 | Ovens
    The fan oven is not heating up. The fan appears to to be operating and the element for the grill heats up . I had the oven element replaced over a year ago.
    If the fan is working o/k, but there is no heat, then it is more than likely the element that has failed again.
    The fact that you had it replaced a year ago, does not mean tha it will last a long tiime, it is quite common for them to fail in a relatively short space of time.
    Take my advice and fit a new element.
    Thankyou.
    Dec 03, 2009 | Baumatic Ovens
    Whirlpool 6MFOS oven not heating
    Do you still have this oven? I broke my glass door and need a replacement. thanks
    Oct 19, 2009 | Whirlpool Ovens
    My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
    Oven functions
    Oven light.
    Upper and lower heating elements.
    (Conventional cooking).
    Upper and lower heating elements with fan.
    (Fan assisted cooking).
    Lower heating element with fan.
    Inner grill heating element.
    (Radiant grill).
    Full grill heating element with fan.
    (Fan grill)
    Rear circular heating element with fan.
    (Fan forced cooking).
    http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
    Oct 10, 2009 | Ovens
    Not heating in fan forced mode
    Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
    Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
    Neff single oven
    fan heating heating element gone replace it ;Ire close bye
    Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
    Kitchen Ranges Logo
    54 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
