Canon iR2318 show paper jam - Office Equipment & Supplies
Restart The Machine if problem persists call service
. problem Please Solve My problem
Posted on Mar 20, 2014
SOURCE: paper jam problem in pixma mp145. E3 error.
I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
Posted on Nov 29, 2008
SOURCE: Canon MP530 shows paper jam,
First – diagnose your problem. In my case the first roller which feeds the paper through the ADF (under small black flip up cover on top) was not turning. Hence no paper advance and error claimed a paper jam (it wasn’t – just a failure to advance paper)
The cause turned out to be a stuck gear turning that silver rod at the top. A bit of household oil has worked a charm.
To get at the gear, unhinge the ADF cover retaining tie (black flexible plastic stopping it opening all the way). Just lift it up and roll over towards printer.
Then unscrew one screw next to that tie. Gently prise plastic cover off by lifting up from left hand side (near that black tie). It should rotate off. Keep power on and fingers out.
Put a few drops of oil on top gear. Place paper in ADF and attempt a batch scan operation. Gears should turn and lubricate parts. Repeat.  Once working, replace cover, screw and tie.
Mine had seized months ago and is now working fine. Hope yours does too.
P.S. Get a Continuous Ink System (as sold on eBay) - awesome for an ink guzzler...
Posted on May 11, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
  • 12 Answers
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Posted on Jun 13, 2009
digitalhubz
  • 109 Answers
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
try this :
Instructions
    • 1 Tap the "Additional Functions" button on your Canon copier.
    • 2 Press the "2" and "8" keys on the number pad simultaneously, and then quickly release them.
    • 3 Tap the "Additional Functions" button again.
    • 4 Tap the "Copier" button when you see the "System Management" screen.
    • 5 Press the "Function" button and then the "Clear" button.
    • 6 Tap the "ERR Button" to highlight all error and status codes that are active.
    • 7 Press the "OK" button, and then restart the copier to finish clearing the error and status codes.
Jul 23, 2014 | Canon Office Equipment & Supplies
Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Jul 17, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
My copier Canon ir2318 shows this message: Update Firmware *BIOS MODE* 2008/08/27 vo.16 Wait Updating F/W
u have to install a new software update through a laptop and u need a new service software tool to do so. so it is better to call a company rep as u will not be able to find it in grey market
Aug 14, 2011 | Office Equipment & Supplies
I have one Canon iR2318/2320 UFRII LT printer. that one is showing Call for service and E000007-0000.I replace the fixing film also but still it is showing the same massege.Can some help me to fix...
i have canon photo copy machine iR2318 and 2318L i want to know
the different between the two machines ihave e-mail addres
antenehhailu@ymail.com
Apr 22, 2010 | Canon imageRUNNER 2200
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Mar 12, 2008 | Canon FAX-B820 Plain Paper Bubblejet
481 people viewed this question
jasbo
jasbo
