Door does not open washing machine LG model(WD-1065QDP)
Clothes still inside the basin
  • 209 Answers
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Posted on Oct 15, 2007
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
  • 3 Answers
SOURCE: Bad smell in our washing machine LG Front Loader WD-8074
I had the same problem.  It's a design flaw with all HE's I have learned, they are too efficient.   I visited my local Sears store and purchased WasherFresh.  I initially tried Affresh made by Whirlpool, did not help at all.  WasherFresh I initially had to use 3 tables to get rid of the buildup and now I use it once a month and now our towels do not smell moldy.  Hope this helps.
Posted on Feb 13, 2009
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
When i wash it smells like rooting eggs i tryed bleach and the tablets but smells up the hole house what wrong its a lg tromm wm-2487hwm steam washer
I had the same problem. You must take out your clothes immediately and leave the door open after every wash to let the inside of the washer completely dry. I believe I read to run a cycle of bleach water and wipe down the inside of the door and interior with bleach/water mixture. Then let it dry. You then can start washing your clothes again, but you must be diligent about leaving the door open to air out between washings.Hope this works for you. I almost sold my machines shortly after I bought them because my clothes were always smelly after washing. Leaving the door open has worked for us.
Dec 18, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
Hi my LG WD-14311RD washing machine refuses to unlock. Cannot open the door,just remains locked.
My model no is LG WD-14331 AD the door just remains locked cant open i think the handle inside plastic hv broken how to solve can u send some one come to repair or .
BR Chow
Jul 29, 2011 | LG WD14311RD Front Load Washer / Dryer
My aged invalid mother has a front loading LG washer dryer combo and has washed the same garment 3 times and after wash cycle or drying cycle can't seem to get the door to open to remove the clothes. What...
Hi I hope you solved this by now but I thought an answer might be useful if anyone else has the same question. I am not an expert just an owner of a LG WD-1412RD. It sounds like your mum is not aware this is just the normal safety cool down period following drying (as the stainless steel interior gets very hot during drying). The Door lock sign (small red light) is on, and the display shows Cd during this time, then it beeps and the door unlocks by itself. If you need to remove your laundry earlier than this, you can press the START/PAUSE button to end the cycle (it still takes a couple of minutes). This is covered on p 21 - 22 of the owners manual. which can be downloaded from the LG site. http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Nov 28, 2010 | LG WD-14124RD Front Load Washer / Dryer
Door won't open after wash cycle..no code or error..
lg huh... go get a hammer or something heavy and break the door glass to get clothes out.... lol ?LG this is whut u get when u buy that shizzzit lol sooorrry but it seems like noone can get parts or service on this brand is what my joke is about., soooorry at ur expense though i jusst had to say that ......well try unpluggin or killin breaker power to unit for five minutes, also make sure no control lock buttton is activated, some machines have a latch up underneath might need to remove bottom panel is acccesible thats bout it hope this helps once again soory for the foul weatherd joke...gooday mate
May 21, 2010 | LG WD-1280FHD Front Load Washer
Lg wd-8013, all lights on at end of cycle door wont open
It sounds like you have a faulty interlock. This is what locks the door during the wash cycle.Sometimes they won't unlock and need to be replaced. There may be a pull tab inside the pump access area at floor level to get door open....Not a big job for a tech......Nomess
Apr 12, 2010 | LG WD-1045FH Front Load Washer
Cant open door
Dear all, I have a problem with washing machine model wd-8013c, then you wash white laundry receives water and immediately released, and it does not happen with colorful Vesa. Best regards.
Apr 25, 2009 | LG Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
