Question about Ryobi Garden
Does the red light go off when the 14.4 battery is chared
On 3hr charger does lijght go out when battery is charged
    Sergeant:
  • 316 Answers
Hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you.
Posted on Feb 18, 2012
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: charger light blinks red never
Worx has had issues with their chargers and their batteries. They don't seem to last as long as the machine does. A simple voltmeter test of the charger and any battery will tell the story. The charger's output rating should be printed on it and the battery also. Touch test leads from voltmeter to the two and check.
Posted on Oct 31, 2010
My JBL CHARE wont charge it will only flash a red light
I assume you mean a JBL Charge. As for that specific model I am unfamiliar, however if when you try to charge electronics they will only flash a red light that's usually a battery or charger error signal. Most likely either a battery in the battery pack has gone bad, a contact has come loose or your charger has broken. Did you happen to drop it shortly before this error occurred? Also was the battery completely dead right before this happened? Sometimes I have noticed wireless devices will refuse to charge a battery if it is completely drained.
Dec 02, 2014 | JBL Audio Players & Recorders
I just got a jbl flip 2 how do I know when it's
The battery take approx 3hr to charge from the supplied JBL charger. Leave it plugged in for 4 hours, then have a look at the battery light indicator on the back panel. Are all the lights lit up? There's your answer.
Sep 06, 2014 | Audio Players & Recorders
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
My dcr sr 80 is not charging
Depending on your camera, the battery may be able to be charged on the camera or by using a separate battery charger. Refer to the section below that relates to the charging method you are using.
Charging while the battery is attached to the camera:
  1. Make sure the battery is firmly attached and the AC adapter is securely connected.
  2. If your camera can charge the battery with a USB connection, use the built-in USB cable to connect it to the computer. If you use a USB charger instead of the computer, check the compatibility of the USB charger.
  3. Turn off the camera. The battery is does not charge if the camera is turned on.
Charging using the battery charger:
  1. If the CHARGE lamp does not light or blinks when charging, the terminals may be dirty. Wipe the dust away with a dry cloth and charge the battery again.
  2. Make sure the metal contacts on the battery are free of corrosion.
Dec 28, 2012 | Sony Handycam DCR-SR80 HD Camcorder
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
The red light shows when the phone is charing, but the phone is not taking charge sonyericsson vivaz
Please do this basic steps.
* try to change the charger to see if its just the problem,even you see the light indicator of the charger,might the cord got intermittent wires due to improper handling or usage. this might happen when you try to roll the entire cord so tight.
* changing the battery is another option,when the battery got drained,the charging current doesn't able to get up,in this case it needs a replacement,might been using this battery for a long time.
* also check the charging pins or terminal if its clean and align,sometimes moisture or corrosion takes place,try to clean it using any pin and scratch the corroded or dirty part or the terminal so the current will continue undergo charging.
I hope this simple steps will definitely solve your problem... Thank you for visiting fixya.
Jul 03, 2011 | Cell Phones
I HAVE A SANYO CHARGER NC61 WHICH SHOWS TWO GREEN LIGHTS WHEN CHARGING, HOW DO I KNOW WHEN THE BATTERIES ARE CHARGED/
Generally speaking,six hours is enough to charing SANYO Battery with full power ,when it is full it will stop charing automatically.
Feb 09, 2011 | Cameras
Just got this little dirt bike from a yard sale. Trying to figure out charging the battery. When I put the charger into the outlet, the little green light comes on. Then when I connect black charger end...
the charger led should turn orange or red when charing then turn green when finished charging, but without knowing the model of the charger its had to say
Dec 12, 2010 | Peg Perego 12v Battery
Charing my battery for a FireStorm 9.6V
Yes, it means the charger is not working. The light is the charge indicator and is red while charging.
Nov 05, 2009 | Drills
I HAVE A DC 222 AND NO INSTUCTIONS I AM CHARGING THE BETTERIES THEY ARE MEANT TO BE A 1 HOUR CHARGE IS THERE A LIGHT TO SAY FULL CHARE? ALL I GET IS A RED BLINKING LIGHT REGARDS MIKE
on the charger usually there is a guide to the different rates and conditions of the charge.some have flashing lights of different rates to indicate charging or fully charged. If you give me the exact model and brand I will try and find a user manual for you
Jul 17, 2009 | Dewalt Drills
Garden Logo
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
