Question about Whirlpool Washing Machines
Hi. I have a Whirlpool 6th sense front loader 11kg washing machine (AWM 1008). After some very cold weather I now have an error code of FA. Do you know what this means and what I need to do? Thanks
    Problem Solver:
  • 9 Answers
Solution from a previous post i found for you.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Most of the solutions i found for this same error were very similar. If all else fails read the manual or get a new washer when possible.
Posted on Feb 17, 2012
4 Suggested Answers
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
  • Check the MCU
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
  • 6 Answers
SOURCE: F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
Posted on Jul 16, 2008
SOURCE: whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Posted on Aug 17, 2008
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Sep 09, 2017 | Whirlpool Washing Machines
Whirlpool awm 8125 fault code F09 followed by FA
The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
My Whirlpool 6th sense washer displayed f09 so I left it. next day it seemed OK but does part of the wash and comes up with FA
Thank you for your response. I finally managed to contact someone at Whirlpool who advised that the error code FA indicates a component problem and may require a replacement part. Unfortunately a serviceman is required.
Jan 29, 2010 | Whirlpool Washing Machines
Hi There
  • Check the MCU
Dec 11, 2009 | Whirlpool Washing Machines
Whirlpool 6th sense front loader awm 8121
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
277 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
