Question about Proform 680 LT Treadmill
Treadmill display panel is not working. will come on in demo mode but none of the buttons work.
  • atsmith76
    atsmith76 Feb 21, 2012
    Checked all of the listed suggestions...no help. Display comes on for approx 2 seconds after turning reset from off to on. Nothing happens (no change) when magnetic key is attached or not.
  • atsmith76
    atsmith76 Feb 23, 2012
    when reset button is cycled, display screen comes on for about 2 seconds and then goes off. After that nothing else will work.
    Top Expert:
  • Proform Master
  • 12,223 Answers
Dear Sir:
Please adjust the reed switch, according with the diagram attached 1/8-1/4". 2) Tight the ribbon cable from keypanel (display board) 3) Tight the connector from display board vs main motor board.
Run the software calibration for reasy diagnose and troubleshooting.
See my block diagram for better undertanding. sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 18, 2012
Treadmill buttons not working
Here is a link to the manual pay close attention to page 16 this will tell you how to see if it is in fact in the demo mode and how to cancel it. Some thing to remember about the display is that it is a matrix with contacts going both horizontal and vertical if one is broken some buttons will work and other won't. You may want to remove the console and clean the ribbon cables.
Mar 18, 2014 | Exercise & Fitness
Nordictrack exp 1000X will only run on pre-programmed
When in Demo Mode, the console will go through a repeating lighting pattern. This mode will only become active when the treadmill is plugged in, the main on/off switch is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be turned off at any time.
ethod #1 to switch from the Demo Mode:
1.the STOP button while inserting the safety key tPress and hold o enter the user information mode.
2.Look in the Calories window. When Demo Mode is active, the letter 'd' will appear.
3.Press the SPEED DOWN button to toggle the mode on and off.
4.Once the mode is set as desired, remove the safety key.
Follow the steps and fix it.
God bless you
Jan 18, 2013 | Exercise & Fitness
Console buttons dont work, deadman key removed goes into demo mode...
Adjust the REED swicht , see diagram, clean it, and tight the plug very well.
2) clean the ribbon cables, for keypads, clean it.
3) tight the connector from display board vs lower board too
see the block diagram
After you fix it. RUN the software calibration for diagnostic, troubleshooting. too
God bless you
Oct 10, 2012 | NordicTrack Exercise & Fitness
Display panel is not working. It will come on in demo mode but none of the buttons work
Dear Sir:
Adjust the reed switch, by 1/8-1/4 see the diagram attached. 2) Tight the ribbon cables from keypanel 3) Tight the connector from display board vs main motor board.
Run the software calibration for easy diagnose and troubleshooting.
See my personal block diagram for easy understanding in troubleshooting. sincerely. God bless you.
ernesto cuadra
Feb 17, 2012 | Proform 680 LT Treadmill
Healthrider will turn on and is in demo mode. will not do anything else.
1) IF THE MACHINE ONLY RUN IN DEMO MODE, TRY TO RUN IN NORMAL POSITION.
2)PUSH AND HOLD ON THE STOP BUTTON BY 5 SECONDS.
3) IF THE PROBLEM PERSIST, TRY TO TIGHT THE FLEXIBLE CORD FROM KEY PANEL VS DISPLAY BOARD.
4)TIGHT THE DISPLAY BOARD VS LOWE BOARD(MAIN MOTOR BOARD)
5) IF THE PROBLEM PERSIST THE MAIN MOTOR CONTROLLER BOARD IS PROBABLY FAULTY.
6)bEFORE TEST THE MAIN MOTOR.
SINCERELY.
12_13_2011_9_19_40_pm.gifSeethe block diagram
Jul 19, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
I have a C2155. In the middle of a run, the treadmill stopped working, but the display remained lit. After looking through the manual I found out it must have gone into demo mode (it's never done...
http://www.youtube.com/watch?v=E-q-uS4t6so
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet.
Do not use an extension cord.
    • 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
    • 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Watch this videos:
Jun 30, 2011 | Nordic Track NordicTrack Treadmill, A2550
I have a 2yr old A2550 which just recently started showing only demo information. The belt would not come on nor would the key change the system to manual mode. I used information mode just to see if...
Method #1 to switch from the Demo Mode:Press and hold the STOP button while inserting the safety key to enter the user
information mode.
appear.
May 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
Stuck on DEMO Mode
Just try to initialize THE plager again. Without cd in the player switch on the power while pressing the Play, Open and Next Track button. On the display it says " initialized" Ready. Frits van Heekesen Nijmegen The Netherlands
Dec 27, 2007 | Denon DVD-2200 DVD Player
Proform 680 LT Treadmill Logo
183 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
